I'm trying to make a VBA macro which would use the user name set in Inventor. I haven't been able to find anything on how to get that username. I would think it would be easily accessable, since it's commonly used to fill in iproperties.
Just in case someone isn't sure what I mean by user name, here is it's location in the options.
Options - General tab - User name: (top right)
Solved by Curtis_Waguespack. Go to Solution.
Hi
There is an example of using the User Name at this link:
http://inventortrenches.blogspot.com/2011/04/using-inventor-ilogic-to-create-e-mail.html
I hope this helps.
Curtis
Thanks for the link. As I though it was a simple bit of code, just fun to search for lol.
