Normally I can get, add and change all the iproperties values below code:
Dim invDocs As Documents
invDocs = inv_App.Documents
Dim i As Integer
Dim invDocument As Document
Dim invPartNumberProperty As Property
For i = 1 To invDocs.Count
invDocument = invDocs.Item(i)
Set invPartNumberProperty = invDocument.PropertySets.Item("Design Tracking Properties").Item("Part Number")
Next
But above code give the all part/asm part list of the all open files in inventor 2013...
I want to get used part/assembly list of only active document. But inv_App.ActiveDocument has not got "For i = 1 To invDocs.Count" propety?!...
How can I iterate and get iproperties values of only active document of the inventor session?...
Mucip:)
Solved by mucip. Go to Solution.
I found solution... 🙂
invDocs = inv_App.ActiveDocument
'Get all of the referenced documents.
Dim oRefDocs As DocumentsEnumerator
oRefDocs = invDocs.AllReferencedDocuments
For Each invDocument In oRefDocs
' Get a specific item from the Documents collection.
Set invPartNumberProperty = doc.PropertySets.Item("Design Tracking Properties").Item("Part Number")
MsgBox(invPartNumberProperty.value)
Next
Mucip:)
