I am trying to select the same sub occurrence in another occurrence of the same object. A sample of the structure is below. I want to select part 1 and be able to find the same sub occurrence from Sub Assembly 1:1 in Sub Assembly 1:2 (Note: they are two occurrences of the same assembly, also there could be many levels to the assembly structure)
Top Level Assembly
Sub Assembly 1:1 Sub Assembly1:2
part 1.ipt ---------> part 1.ipt
part 1.ipt part 1.ipt
part 2.ipt part 2.ipt
part 3 .ipt part 3.ipt
Is this possible? Any help would be appreciated.
Thanks, Matt.
Hope the Occurrences.AllReferencedOccurrences(Document) can help you.
