Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Get the active sketch
2 REPLIES 2
CadUser46
726 Views, 2 Replies
Is there some simple way to get the sketch number of the active sketch in either part or assembly?
I understand the document.sketchactive boolean but this doesnt allow me to find which sketch in the collection is the active one.
Inventor 2010 Certified Professional
Currently using 2023 Pro
2 REPLIES 2
Hi CadUser46,
I use something like this in iLogic to find the active sketch name:
Dim oSketch As PlanarSketch
If Typeof ThisApplication.ActiveEditObject Is Sketch Then
oSketch = ThisApplication.ActiveEditObject
MessageBox.Show(oSketch.Name & " is the active Sketch", "iLogic")
Else
MessageBox.Show("Active Edit Object is not a Sketch", "iLogic")
End If
 There might be a better way, but this is what I had handy.
It occurred me after I posted the above that we could so something like this to find the active sketch number as you requested:
Dim oSketches As PlanarSketches
oSketches = ThisApplication.ActiveDocument.ComponentDefinition.Sketches
i=1
For Each oSketch in oSketches
	oSketch = oSketches.Item(i)
		If oSketch Is ThisApplication.ActiveEditObject Then
		MessageBox.Show("The active sketch is number: " & i, "iLogic")
		Else
		End If
	i=i+1
Next
I hope this helps.
Curtis
As sketch number in the sketches collection could be changed it is safer to use Sketch.Name property to reference the particular Sketch.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
