Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Get/Set iProperty directly with Id Enum
5 REPLIES 5
2701 Views, 5 Replies
It is possible get/set a iPropety value directly using the Id Enum.
Here can I get same C# sample.
Thanks & regards,
Rui
5 REPLIES 5
rjay75
What ID enum are you refering too? Can you give a snippet of how you would like to refer to an iProperty?
in reply to: rjay75
What I want is an direct way in C# to get/set the value of a iProperty.
Not just for the main document but for the referenced documents too.
Follow the table with the list of iProperties with ProtertyName/Id/Id Enum.
Inventor User Defined Properties,
{D5CDD505-2E9C-101B-9397-08002B2CF9AE}
Inventor Summary Information,
{F29F85E0-4FF9-1068-AB91-08002B27B3D9}
Property Name
Id
Id Enum
Type
Title
2
kTitleSummaryInformation
String
Subject
3
kSubjectSummaryInformation
String
Author
4
kAuthorSummaryInformation
String
Keywords
5
kKeywordsSummaryInformation
String
Comments
6
kCommentsSummaryInformation
String
Last Saved By
8
kLastSavedBySummaryInformation
String
Revision Number
9
kRevisionSummaryInformation
String
Thumbnail
17
kThumbnailSummaryInformation
IPictureDisp
Inventor Document Summary Information,
{D5CDD502-2E9C-101B-9397-08002B2CF9AE}
Property Name
Id
Id Enum
Type
Category
2
kCategoryDocSummaryInformation
String
Manager
14
kManagerDocSummaryInformation
String
Company
15
kCompanyDocSummaryInformation
String
Design Tracking Properties,
{32853F0F-3444-11D1-9E93-0060B03C1CA6}
Property Name
Id
Id Enum
Type
Creation Time
4
kCreationDateDesignTrackingProperties
Date
Part Number
5
kPartNumberDesignTrackingProperties
String
Project
7
kProjectDesignTrackingProperties
String
Cost Center
9
kCostCenterDesignTrackingProperties
String
Checked By
10
kCheckedByDesignTrackingProperties
String
Date Checked
11
kDateCheckedDesignTrackingProperties
Date
Engr Approved By
12
kEngrApprovedByDesignTrackingProperties
String
Engr Date Approved
13
kDateEngrApprovedDesignTrackingProperties
Date
User Status
17
kUserStatusDesignTrackingProperties
String
Material
20
kMaterialDesignTrackingProperties
String
Part Property Revision Id
21
kPartPropRevIdDesignTrackingProperties
String
Catalog Web Link
23
kCatalogWebLinkDesignTrackingProperties
String
Part Icon
28
kPartIconDesignTrackingProperties
IPictureDisp
Description
29
kDescriptionDesignTrackingProperties
String
Vendor
30
kVendorDesignTrackingProperties
String
Document SubType
31
kDocSubTypeDesignTrackingProperties
String
Document SubType Name
32
kDocSubTypeNameDesignTrackingProperties
String
Proxy Refresh Date
33
kProxyRefreshDateDesignTrackingProperties
Date
Mfg Approved By
34
kMfgApprovedByDesignTrackingProperties
String
Mfg Date Approved
35
kDateMfgApprovedDesignTrackingProperties
Date
Cost
36
kCostDesignTrackingProperties
Currency
Standard
37
kStandardDesignTrackingProperties
String
Design Status
40
kDesignStatusDesignTrackingProperties
Long
Designer
41
kDesignerDesignTrackingProperties
String
Engineer
42
kEngineerDesignTrackingProperties
String
Authority
43
kAuthorityDesignTrackingProperties
String
Parameterized Template
44
kParameterizedTemplateDesignTrackingProperties
Boolean
Template Row
45
kTemplateRowDesignTrackingProperties
String
External Property Revision Id
46
kExternalPropRevIdDesignTrackingProperties
String
Standard Revision
47
kStandardRevisionDesignTrackingProperties
String
Manufacturer
48
kManufacturerDesignTrackingProperties
String
Standards Organization
49
kStandardsOrganizationDesignTrackingProperties
String
Language
50
kLanguageDesignTrackingProperties
String
Defer Updates
51
kDrawingDeferUpdateDesignTrackingProperties
Boolean
Size Designation
52
String
Categories
56
kCategoriesDesignTrackingProperties
String
Stock Number
55
kStockNumberDesignTrackingProperties
String
Weld Material
57
kWeldMaterialDesignTrackingProperties
String
rjay75
To use the propId the most straight forward way will be
doc.PropertySets[name / index].ItemByPropId(propId)
where doc a document object.
in reply to: rjay75
It is possible get the type of the property? If is String, Date, IPictureDispLong, Currency or Boolean?
Apparently the "Property.Type() As ObjectTypeEnum" returns always "kPropertyObject" and not if is String, Date, IPictureDispLong, Currency or Boolean
rjay75
Simplest way to get the type of the value is to test if the Property.value is not null, then get the result of the GetType .NET method. This will return the .NET type of the value.
Property.Value.GetType()
You still want to know what property you are refering to because it may be a calculater result in which you need to use Property.Expression to get the expression calulation since the Value will just be the result.
