Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Get handle of parent window? Needed to keep focus on a popup window.
4 REPLIES 4
cpicke
493 Views, 4 Replies
I have a script that opens a popup form when a custom button is clicked in the ribbon. In the code, this was implemented using the code snippet:
override protected void ButtonDefinition_OnExecute(NameValueMap context)
    if (InventorApplication.ActiveEditObject is Inventor.PartDocument)
        MyWin win = new MyWin();
        win.Show();
    else
        MessageBox.Show("A part document must be active for this command");
Also note that this window must not be modal i.e., I cannot use win.ShowMessage(); because there is a button on this window that invokes e.g., the line of code
pickedFace = StandardAddInServer.m_inventorApplication.CommandManager.Pick(Inventor.SelectionFilterEnum.kPartFaceFilter,"Pick Face") as Face;
which will not work properly if the window is modal.
I wish to keep focus on MyWin. You would think that one way to do this is to put the handle of the parent window inside the parentheses of win.Show(); However, the parent window appears to be the Inventor main window itself. Does anybody know what is the handle of the parent window, so I can keep focus on the popup window MyWin?
Thank you.
4 REPLIES 4
rjay75
in reply to: cpicke
Here's the code to get Inventor's window handle to do what you need.
        void btnDoSomething_OnExecute(NameValueMap Context)
            MyWinForm myWin = null;
            if (appInventor.ActiveDocument.DocumentType == DocumentTypeEnum.kPartDocumentObject)
                myWin = new MyWinForm();
                NativeWindow hWnd = new NativeWindow();
                hWnd.AssignHandle((IntPtr)m_inventorApplication.MainFrameHWND);
                myWin.Show(hWnd);
else
in reply to: rjay75
Hello!
is it possible to get the code in VBA too? in order to get the Window handle in VBA?
thanks!
GeorgK
You can use the converter:
http://converter.telerik.com/
in reply to: GeorgK
never mind I found a premade command:
SyntaxEditor Code Snippet
ThisApplication.MainFrameHWND
