Is it possible to have iLogic form automatically open, when iLogic part/assembly opens?
Alex
Solved by MegaJerk. Go to Solution.
I'm not sure if there is an easier way to do this, but you could always create a new ilogic rule, and use the code snippet for form opening --
iLogicForm.Show("Form 1")
Then go to Manage -> Event Triggers, and add that newly created rule to the After Open selection.
It's not elegant, but I haven't had much of a chance to really dig into the forms too much so there might be a way more obviously easy way of doing this...
I've tried to do that in 2015 and set the ilogic rule to open my form on "new". The form will not open and get dirty. It works nicely when i run the rules, also the open form ilogic, but as soom as i use the template with the rule to open the form the form gets unusable..
Here's the code :
iLogicForm.Show("Select Company")
Here's the ilogic error :
iLogic Event-Driven Rule
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Here's the NET error message :
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor._DocumentClass.get_RevisionId()
at iLogic.UiBuilderConnect.NonModalEventsManager..ctor(InventorDocumentConnector documentConnector, DynamicForm form, Boolean hasPropertyControls)
at iLogic.UiBuilderConnect.InventorDocumentConnector.ShowForm(FormSpecification formSpec, UiStorage storage)
at DevExpress.XtraEditors.BaseButton.OnMouseUp(MouseEventArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at DevExpress.Utils.Controls.ControlBase.WndProc(Message& m)
at DevExpress.XtraEditors.BaseControl.WndProc(Message& msg)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.18444 built by: FX451RTMGDR
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
WpfHost
Assembly Version: 0.0.0.0
Win32 Version: 19, 0, 15900, 0000
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/WpfHost.DLL
System
Win32 Version: 4.0.30319.18408 built by: FX451RTMGREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
InvAIRLookContent
Assembly Version: 19.0.15900.0
Win32 Version: 19.0.15900.0000
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/InvAIRLookContent.DLL
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
WindowsBase
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
WpfAppPage
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/WpfAppPage.DLL
InvAIRLookResources
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/InvAIRLookResources.DLL
FlowRibbon
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/FlowRibbon.DLL
AdWindows
Assembly Version: 5.2.8.100
Win32 Version: 5.2.8.100
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/AdWindows.DLL
InvRibbonUIResources
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/InvRibbonUIResources.DLL
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
InvAIRLookContent.resources
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/en-US/InvAIRLookContent.resources.DLL
InvAIRLookColorImages
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/InvAIRLookColorImages.DLL
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
InvRibbonUIResources.resources
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/en-US/InvRibbonUIResources.resources.DLL
WpfAppPage.resources
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/en-US/WpfAppPage.resources.DLL
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
AdApplicationFrame
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/AdApplicationFrame.DLL
PresentationFramework-SystemCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Microsoft.Expression.Interactions
Assembly Version: 4.5.0.0
Win32 Version: 3.0.40218.0
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Microsoft.Expression.Interactions.DLL
WindowsFormsIntegration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
ManagedMC3
Assembly Version: 8.2.0.0
Win32 Version: 8.2.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/ManagedMC3.DLL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PresentationFramework-SystemXml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
InvTutorial
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/InvTutorial.DLL
ClrAddinLoader
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/ClrAddinLoader.DLL
Naviate.Pos
Assembly Version: 2014.2.9.0
Win32 Version: 2014.2.9
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.Pos.dll
Naviate.ConfiguratorData
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.ConfiguratorData.DLL
InventorUtils
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/InventorUtils.DLL
Autodesk.Inventor.Interop
Assembly Version: 17.0.0.0
Win32 Version: 17.0.0.0
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Autodesk.Inventor.Interop/v4.0_17.0.0.0__d84147f8b4276564/Autodesk.Inventor.Interop.dll
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 11.0.50938.18408 built by: FX451RTMGREL
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
NVLicensing
Assembly Version: 2014.2.1.5879
{c898180a-1dd0-4330-983c-7f5cb3dfb18a}
System.Management
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
System.Web
Win32 Version: 4.0.30319.18446 built by: FX451RTMGDR
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
Naviate.ERPLookup
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.ERPLookup.dll
ADODB
Assembly Version: 7.0.3300.0
Win32 Version: 7.10.6070
CodeBase: file:///C:/Windows/assembly/GAC/ADODB/7.0.3300.0__b03f5f7f11d50a3a/ADODB.dll
CQ.Navigator
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/CQ.Navigator.dll
ObjectListView
Assembly Version: 2.5.1.19572
Win32 Version: 2.5.1.0
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/ObjectListView.DLL
edtFTPnet
Assembly Version: 2.0.1.0
Win32 Version: 2.0.1.0
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/edtFTPnet.dll
Interop.CQ_ODWBundleComponent
Assembly Version: 1.1.0.0
Win32 Version: 1.1.0.0
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Interop.CQ_ODWBundleComponent.dll
Ionic.Zip
Assembly Version: 1.9.1.5
Win32 Version: 1.9.1.5
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Ionic.Zip.dll
Naviate.AutoDXF
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.AutoDXF.dll
Naviate.CenterOfGravity
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.CenterOfGravity.dll
Naviate.ConfiguratorControls
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.ConfiguratorControls.dll
System.Configuration.Install
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration.Install/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.Install.dll
Naviate.DBL
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.DBL.dll
Naviate.DCC
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.DCC.dll
Naviate.drawRectangle
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.drawRectangle.dll
Naviate.DRC
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.DRC.dll
Naviate.Export
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.Export.dll
Naviate.FWO
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.FWO.dll
Naviate.GroundToOrigin
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.GroundToOrigin.dll
Naviate.Help
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.Help.dll
Naviate.InventorQuickOpen
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.InventorQuickOpen.dll
Naviate.MakeDrawing
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.MakeDrawing.dll
Naviate.Navigator
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.Navigator.dll
Naviate.Navigator.Settings
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.Navigator.Settings.dll
Naviate.numberGenerator
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.numberGenerator.dll
Naviate.PCP
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.PCP.dll
Naviate.Properties
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.Properties.dll
Naviate.QuickOpen
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.QuickOpen.dll
Naviate.QuickPrint
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.QuickPrint.dll
Naviate.RWC
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.RWC.dll
Naviate.UUP
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Naviate.UUP.dll
System.Design
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
stdole
Win32 Version: 7.00.9466
CodeBase: file:///C:/Windows/assembly/GAC/stdole/7.0.3300.0__b03f5f7f11d50a3a/stdole.dll
CustomMarshalers
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/CustomMarshalers/v4.0_4.0.0.0__b03f5f7f11d50a3a/CustomMarshalers.dll
Autodesk.iLogic
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.iLogic.DLL
Autodesk.iLogic.CommonUI
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.iLogic.CommonUI.DLL
Autodesk.iLogic.Interfaces
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.iLogic.Interfaces.DLL
Autodesk.iLogic.UiBuilder
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.iLogic.UiBuilder.DLL
Assembly Version: 19.0.0.0
Win32 Version: 19.0.0.0
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Autodesk.Inventor.Interop/v4.0_19.0.0.0__d84147f8b4276564/Autodesk.Inventor.Interop.dll
Autodesk.iLogic.Core
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.iLogic.Core.DLL
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.iLogic.Common.DLL
Autodesk.iLogic.DesignCopy
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.iLogic.DesignCopy.DLL
Connectivity.InventorAddin.EdmAddin
Assembly Version: 19.0.49.0
Win32 Version: 19.0.49.0
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.InventorAddin.EdmAddin.DLL
Connectivity.Common
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Common.DLL
Autodesk.DataManagement.Addin.Framework
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.DataManagement.Addin.Framework.DLL
Autodesk.DataManagement.Addin.Vault
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.DataManagement.Addin.Vault.DLL
Autodesk.DataManagement.Client.Framework
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.DataManagement.Client.Framework.DLL
Autodesk.DataManagement.Client.Framework.Forms
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.DataManagement.Client.Framework.Forms.DLL
DevExpress.Utils.v13.1
Assembly Version: 13.1.5.0
Win32 Version: 13.1.5.0
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.Utils.v13.1/v4.0_13.1.5.0__b88d1754d700e49a/DevExpress.Utils.v13.1.dll
Autodesk.DataManagement.Client.Framework.Vault
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.DataManagement.Client.Framework.Vault.DLL
DevExpress.Data.v13.1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.Data.v13.1/v4.0_13.1.5.0__b88d1754d700e49a/DevExpress.Data.v13.1.dll
Microsoft.VisualBasic.Compatibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic.Compatibility/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.Compatibility.dll
Autodesk.Connectivity.WebServices
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.Connectivity.WebServices.DLL
InventorVault
Win32 Version: 19,0,49,0
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/InventorVault.DLL
Connectivity.Common.Vault
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Common.Vault.DLL
Connectivity.Request.Vault
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Request.Vault.DLL
Connectivity.Request.Common
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Request.Common.DLL
Connectivity.Request.Runtime
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Request.Runtime.DLL
Connectivity.Inventor.Forms
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Inventor.Forms.DLL
Microsoft.Web.Services3
Assembly Version: 3.0.0.0
Win32 Version: 3.0.5305.0
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.Web.Services3/3.0.0.0__31bf3856ad364e35/Microsoft.Web.Services3.dll
Autodesk.Connectivity.Extensibility.Framework
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.Connectivity.Extensibility.Framework.DLL
System.Web.Services
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Web.Services/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.Services.dll
EMA2015
Assembly Version: 5.1.2.0
Win32 Version: 5.1.2.0
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/EMA2015.DLL
Granta.Gateway.DotNetInterface
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Granta.Gateway.DotNetInterface.DLL
ADICommon
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/ADICommon.DLL
InvWorkflowMgd
Assembly Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/InvWorkflowMgd.DLL
UIAutomationTypes
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
CCAddIn
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/CCAddIn.DLL
Mockup360Addin
Assembly Version: 18.0.17000.0
Win32 Version: 18.0.17000.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/Mockup360Addin2015.bundle/Contents/Mockup%20360/Mockup360Addin.dll
Mockup360AddinClient
Assembly Version: 4.0.23190.1002
Win32 Version: 4.0.23190.1002
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/Mockup360Addin2015.bundle/Contents/Mockup%20360/Mockup360AddinClient.DLL
Microsoft.GeneratedCode
Naviate.Navigator.AddPropsToIDW.Addin
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Addins/Naviate.Navigator.AddPropsToIDW.Addin.dll
Naviate.Navigator.RenameCustomProperties.Addin
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Addins/Naviate.Navigator.RenameCustomProperties.Addin.dll
Naviate.Navigator.ScaleInDrawing.Addin
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Addins/Naviate.Navigator.ScaleInDrawing.Addin.dll
Naviate.Navigator.SheetMetalXYZLength.Addin
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Addins/Naviate.Navigator.SheetMetalXYZLength.Addin.dll
Naviate.Navigator.SweepLength.Addin
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Addins/Naviate.Navigator.SweepLength.Addin.dll
Naviate.Navigator.Weight.Addin
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Addins/Naviate.Navigator.Weight.Addin.dll
Naviate.Navigator.XYZLength.Addin
CodeBase: file:///C:/Program%20Files/CAD-Q/Naviate/Manufacturing%202014/Addins/Naviate.Navigator.XYZLength.Addin.dll
PresentationFramework.Luna
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
Autodesk.DataManagement.Addin.Workflow
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.DataManagement.Addin.Workflow.DLL
Autodesk.DataManagement.Client.Framework.Vault.Forms
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.DataManagement.Client.Framework.Vault.Forms.DLL
Connectivity.Application.VaultBase
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Application.VaultBase.DLL
Connectivity.Explorer.Framework
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Explorer.Framework.DLL
Connectivity.Explorer.Document.Objects
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Explorer.Document.Objects.DLL
Connectivity.Common.SharedLibCSharp
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Common.SharedLibCSharp.DLL
Autodesk.DataManagement.Addin.UI
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Autodesk.DataManagement.Addin.UI.DLL
Connectivity.Request.Foundation
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Request.Foundation.DLL
Connectivity.Explorer.Item
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Explorer.Item.DLL
DevExpress.XtraEditors.v13.1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.XtraEditors.v13.1/v4.0_13.1.5.0__b88d1754d700e49a/DevExpress.XtraEditors.v13.1.dll
Connectivity.Request.Document
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Request.Document.DLL
Connectivity.Proxies.Utils
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Proxies.Utils.DLL
Connectivity.Request.Item
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Request.Item.DLL
Connectivity.Request.ChangeOrder
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Request.ChangeOrder.DLL
Connectivity.Common.Windows
Assembly Version: 1.0.5163.32579
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Common.Windows.DLL
Connectivity.Explorer.Foundation
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Explorer.Foundation.DLL
DevExpress.XtraBars.v13.1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.XtraBars.v13.1/v4.0_13.1.5.0__b88d1754d700e49a/DevExpress.XtraBars.v13.1.dll
DataManagement.Common.Logging
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/DataManagement.Common.Logging.DLL
Connectivity.Common.BatchPlot
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Common.BatchPlot.DLL
Accessibility
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
DevExpress.XtraNavBar.v13.1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.XtraNavBar.v13.1/v4.0_13.1.5.0__b88d1754d700e49a/DevExpress.XtraNavBar.v13.1.dll
Connectivity.Proxies.KnowledgeVault
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Proxies.KnowledgeVault.DLL
Connectivity.Proxies.Admin
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Proxies.Admin.DLL
Connectivity.Proxies.Replication
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Proxies.Replication.DLL
Connectivity.Proxies.Security
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Proxies.Security.DLL
Connectivity.Proxies.Information
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Proxies.Information.DLL
Connectivity.Services.Item
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Services.Item.DLL
Win32 Version: 9.0.11.0
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Common.SharedLib.DLL
InventorServiceWrapper
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/InventorServiceWrapper.DLL
Connectivity.ClientShared.Doc.API
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.ClientShared.Doc.API.DLL
Connectivity.Proxies.Job
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/Connectivity.Proxies.Job.DLL
DWFGenerator
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/DWFGenerator.DLL
DWFLibrary
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/DWFLibrary.DLL
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
LegacyPipeline
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/LegacyPipeline.DLL
CCCBL
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/CCCBL.DLL
CCServerProxies.Object
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/CCServerProxies.Object.DLL
AssemblyBonusTools
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/assemblybonustools.DLL
AssemblyBonusToolsRes
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/en-US/AssemblyBonusToolsRes.dll
QuickViewsAddin
Assembly Version: 1.4.0.0
Win32 Version: 1.4.0.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/CadQualityEuropeAB_QuickViews.bundle/Contents/QuickViewsAddin.dll
Assembly Version: 18.0.0.0
Win32 Version: 18.0.0.0
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Autodesk.Inventor.Interop/v4.0_18.0.0.0__d84147f8b4276564/Autodesk.Inventor.Interop.dll
QuickViews
Assembly Version: 1.2.0.0
Win32 Version: 1.2.0.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/CadQualityEuropeAB_QuickViews.bundle/Contents/QuickViews.DLL
SerialCheck
Win32 Version: 1.0.0.0
CodeBase: file:///C:/ProgramData/Autodesk/ApplicationPlugins/CadQualityEuropeAB_QuickViews.bundle/Contents/SerialCheck.DLL
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
DevExpress.XtraLayout.v13.1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/DevExpress.XtraLayout.v13.1/v4.0_13.1.5.0__b88d1754d700e49a/DevExpress.XtraLayout.v13.1.dll
WindowsFormsUtils
CodeBase: file:///C:/Program%20Files/Autodesk/Inventor%202015/Bin/WindowsFormsUtils.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
