I have a solid body made by a single feature Extrude. A simple plate. I wish to find face pair, of two bigger faces, which are opposite of each other.
For a function, I pass one of the big faces, and wish to find opposite face of it, within same body. Tried following logic but does not work:
Private Function findDistanceToOppsiteFace(ByRef face As Inventor.Face, ByRef feat As PartFeature) As Double
findDistanceToOppsiteFace = 0.0
Dim origin As Inventor.Point = face.PointOnFace
Dim pt(2) As Double
Dim n(2) As Double
pt(0) = origin.X : pt(1) = origin.Y : pt(2) = origin.Z
face.Evaluator.GetNormalAtPoint(pt, n)
Dim normal As Inventor.UnitVector = _invApp.TransientGeometry.CreateUnitVector(n(0), n(1), n(2))
Dim body As SurfaceBody = feat.SurfaceBodies.Item(1)
Dim radius As Double = Math.Sqrt(face.Evaluator.Area) * 2.0
Dim objects As ObjectsEnumerator
Dim pts As ObjectsEnumerator
Dim objtypes(0 To 1) As SelectionFilterEnum
objtypes(1) = SelectionFilterEnum.kPartFaceFilter
'body.FindUsingRay(origin, normal, radius, objects, pts, True)
objects = m_partDoc.ComponentDefinition().FindUsingVector(origin, normal, objtypes)
findDistanceToOppsiteFace = _invApp.MeasureTools.GetMinimumDistance(origin, objects.Item(1))
End Function
Solved by ekinsb. Go to Solution.
You were very close. Here's some VBA code that works.
Public Sub TestFindDistance() Dim planeFace As face Set planeFace = ThisApplication.CommandManager.Pick(kPartFacePlanarFilter, "Pick a planar face.") Dim dist As Double dist = findDistanceToOppositeFace(planeFace) MsgBox "Distance: " & dist End Sub Private Function findDistanceToOppositeFace(ByRef face As Inventor.face) As Double findDistanceToOppositeFace = 0 Dim origin As Inventor.Point Set origin = face.PointOnFace Dim pt(2) As Double pt(0) = origin.X: pt(1) = origin.Y: pt(2) = origin.Z ' Get the normal of the face and create a vector in the reverse direction ' because the face normal points out of the solid. Dim n(2) As Double Call face.Evaluator.GetNormalAtPoint(pt, n) Dim normal As Inventor.UnitVector Set normal = ThisApplication.TransientGeometry.CreateUnitVector(-n(0), -n(1), -n(2)) ' Get the parent body. Dim body As SurfaceBody Set body = face.Parent ' Find all faces intersected by a ray. Dim objects As ObjectsEnumerator Dim pts As ObjectsEnumerator Call body.FindUsingRay(origin, normal, 0.001, objects, pts, True) ' Calculate the distance using the second face because the first one will ' be the original input face. findDistanceToOppositeFace = ThisApplication.MeasureTools.GetMinimumDistance(origin, objects.Item(2)) End Function
Ok. You've found the distance to opposite face but what about the face itself, how can i find it via distance?
