Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Find Sheet Metal Thickness with VB.Net
1 REPLY 1
Raider_71
2758 Views, 1 Reply
Hi guys I am looking for a solid way of finding the Thickness parameter of a sheet metal part. I have tried two ways so far:
1. oCompDef.Parameters.Item(Thickness)
This works but if Inventor is installed with a different language pack like German for instance then it fails
2. oCompDef.Parameters.Item(1).Value
This also works but if the user started the part with a normal part template and then converts the part to a sheet metal part down the line, then this method fails.
Any bright ideas?  Smiley Frustrated
Thanks a lot guys
Pieter
1 REPLY 1
nmunro
in reply to: Raider_71
VBA - Mostly taken from an example in the help system (always the first place to look)
Public Sub GetThick()
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    ' Make sure the document is a sheet metal document.
    If oPartDoc.SubType  "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
        MsgBox "A sheet metal document must be open."
        Exit Sub
    Dim oSheetMetalCompDef As SheetMetalComponentDefinition
    Set oSheetMetalCompDef = oPartDoc.ComponentDefinition
    Dim thickParam As Parameter
    Set thickParam = oSheetMetalCompDef.Thickness
End Sub
https://c3mcad.com
