Hi guys I am looking for a solid way of finding the Thickness parameter of a sheet metal part. I have tried two ways so far:
1. oCompDef.Parameters.Item(Thickness)
This works but if Inventor is installed with a different language pack like German for instance then it fails
2. oCompDef.Parameters.Item(1).Value
This also works but if the user started the part with a normal part template and then converts the part to a sheet metal part down the line, then this method fails.
Any bright ideas?
Thanks a lot guys
Pieter
