Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Find Part in browser - drawing
8 REPLIES 8
Message 1 of 9
GeorgK
1267 Views, 8 Replies
Hello together,
how could I find a part with a given name in the browser of a drawing?
Thanky you very much
Georg
8 REPLIES 8
Message 2 of 9
wayne.brill
in reply to: GeorgK
He Georg,
Below is some VBA code that prints out names of parts in the browser. (most of this is from an example in the API Help). You could add an If statement to get the part you wanted. This may not do exactly what you want but it should show how to get to objects from the browser nodes.
Also there are other ways to get the parts and assemblies that are being used by a drawing. (The  DrawingView.ReferencedDocumentDescriptor for example)
Private Sub QueryModelTree()
    Dim Doc As Document
    If (ThisApplication.Documents.count <> 0) Then
        Set Doc = ThisApplication.ActiveDocument
    Else
        MsgBox "There are no open documents!"
        Exit Sub
    Dim oTopNode As BrowserNode
    Set oTopNode = Doc.BrowserPanes("Model").TopNode
Call recurse(oTopNode)
End Sub
Sub recurse(node As BrowserNode)
    If (node.Visible = True) Then
       ' Debug.Print node.BrowserNodeDefinition.Label
        Dim oNativeObj As Object
        Set oNativeObj = node.NativeObject
       ' Debug.Print TypeName(oNativeObj)
        Dim oDoc As Document
        Dim oAsmCompDef As AssemblyComponentDefinition
        Dim oCompOcc As ComponentOccurrence
        Dim oCompOccproxy As ComponentOccurrenceProxy
        If TypeName(oNativeObj) = "AssemblyComponentDefinition" Then
            Set oAsmCompDef = node.NativeObject
            Set oDoc = oAsmCompDef.Document
            Debug.Print oDoc.DisplayName
        If TypeName(oNativeObj) = "ComponentOccurrence" Then
            Set oCompOcc = node.NativeObject
            Set oDoc = oCompOcc.Definition.Document
        If TypeName(oNativeObj) = "ComponentOccurrenceProxy" Then
            Set oCompOccproxy = node.NativeObject
            Debug.Print oCompOccproxy.name
            Set oDoc = oCompOccproxy.NativeObject.Definition.Document
        Dim bn As BrowserNode
        For Each bn In node.BrowserNodes
            Call recurse(bn)
        Next
End Sub
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Message 3 of 9
GeorgK
in reply to: wayne.brill
Hello Wayne,
thanks for the code. But thats not what I am looking for.
Georg
Message 4 of 9
wayne.brill
in reply to: GeorgK
Hi Georg,
Please add more detail to what you are trying to do. It may help to attach a drawing and the parts it is using.
Wayne
Wayne Brill
Message 5 of 9
GeorgK
Hello Wayne,
how could I select the part in the browser and expand it? I know the name from the part already.
Thank you
Georg
Message 6 of 9
GeorgK
in reply to: GeorgK
I found a sample:
http://adndevblog.typepad.com/manufacturing/2012/09/parse-browsernodes-for-a-specified-node-and-perf...
But how could I get the full name of a selected part inluding the view etc.?
Set oBrowserNode = GetBrowserNodeByFullPath("Assembly1:Sheet:1:VIEW1:Assembly1.iam:Assembl
Message 7 of 9
wayne.brill
in reply to: GeorgK
How is the Part selected? Are you asking the user to select the part? I am asking this because from what I can determine a drawing curve needs to be selected in the view to be able to get the document. (to get the parts name). If your code is prompting the user to select a part in a view you could use a filter so the user can only select a drawing curve. (kDrawingCurveSegmentFilter) See this example in the help on how to create a select event in VBA. (Sub TestSelection)
When a Part is selected in a drawing view the selected object in the SelectSet is a GenericObject . (you can see this in the VBA Watch window) The GenericObject does not provide any properties to get information from the API.
Here is a VBA example that is just showing what part of the API I am suggesting to get to the document. If an edge (not an edge of a face) of a part in a view is selected a MsgBox will display the document name and view name. (this example could be updated to handle ModelGeometry returning a face)
Public Sub SelSetTest3()
     Dim oDrwCrvSeg As Object
    Set oDrwCrvSeg = ThisApplication.ActiveDocument.SelectSet(1)
 If Not oDrwCrvSeg Is Nothing Then
      Dim oDrwCrv As DrawingCurve
      Set oDrwCrv = oDrwCrvSeg.Parent
      Dim oEdge As Edge
      Set oEdge = oDrwCrv.ModelGeometry
      Dim oSrfBody As SurfaceBody
      Set oSrfBody = oEdge.Parent
      Dim oCompDef As ComponentDefinition
      Set oCompDef = oSrfBody.ComponentDefinition
      Set oDoc = oCompDef.Document
      MsgBox oDoc.FullFileName
      Dim oDrwView As DrawingView
      Set oDrwView = oDrwCrv.Parent
      MsgBox oDrwView.Name
End Sub
Wayne
Wayne Brill
Message 8 of 9
GeorgK
Hello Wayne,
thank you very much for your help. But how could I bring the code together? I could not get the part selected in the browser.
Georg
Message 9 of 9
wayne.brill
in reply to: GeorgK
Hi Everyone,
This DevBlog post has a VB.NET example
Wayne
Wayne Brill
