Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Find cell in custom table
2 REPLIES 2
621 Views, 2 Replies
I'm trying to search a custom table and output the values using a for loop. I'm having trouble accessing the cells in the column I want though. The problem child seems to be Line 18. Any help would be appreciated.
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim sheet1 as Sheet = oDrawDoc.Sheets("Sheet:1")
Dim table As CustomTable = sheet1.CustomTables.Item(1)
MessageBox.Show("0", "Title")
' Iterate through the contents of the parts list.
Dim i As Long
For i = 1 To table.Rows.Count
MessageBox.Show(i, "Title")
'look at only the DWG NO. column
oCell  = table.Rows.Item(i).Item("DWG NO.")
MessageBox.Show(oCell, "Title")
Next
2 REPLIES 2
gadurai
I think you are missing the declaration for Ocell. In your code declare the following
Dim oCell As Cell
Messagebox.Show(oCell.Value,"Title").
The Following is my VBA code for your reference.
Set oDrawDoc = ThisApplication.ActiveDocument
Dim sheet1 As Sheet
Set sheet1 = oDrawDoc.Sheets("Sheet:1")
Set table = sheet1.CustomTables.Item(1)
Dim i As Long
Dim oCell As Cell
Set oCell = table.Rows.Item(i)(2)
Debug.Print (oCell.Value)
Next
End Sub
Appadurai.G
in reply to: gadurai
That's perfect thank you
