Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Filesystemobject in ilogic
5 REPLIES 5
DWhiteley
1976 Views, 5 Replies
I'm looking to do a recusrive search of a file in a folder using iLogic, but I need to access Filesystemobject
how do I access these in iLogic?
Dim FSO AsNew FileSystemObject
Dim myFolder As Folder
Dim mySubFolder As Folder
Many thanks in advance,
Dave
5 REPLIES 5
alyssaweaver
in reply to: DWhiteley
Not sure of how to through iLogic....
But here's some VBA stuff to get you on the right track...Folder Dialog
    Dim pathSelected As String        'Allows the user to select a folder
    Dim ShellApp As Object
    Set ShellApp = CreateObject("Shell.Application"). _
    BrowseforFolder(0, "Choose Folder", 0, OpenAt)
    pathSelected = ShellApp.self.path
        Me.TextBox1.Text = pathSelected
    Set ShellApp = Nothing
 OpenFileDialog:
Public Declare Function GetOpenFileName Lib "comdlg32.dll" Alias "GetOpenFileNameA" (pOpenfilename As OPENFILENAME) As Long
Public Type OPENFILENAME
    lStructSize As Long
    hwndOwner As Long
    hInstance As Long
    lpstrFilter As String
    lpstrCustomFilter As String
    nMaxCustFilter As Long
    nFilterIndex As Long
    lpstrFile As String
    nMaxFile As Long
    lpstrFileTitle As String
    nMaxFileTitle As Long
    lpstrInitialDir As String
    lpstrTitle As String
    flags As Long
    nFileOffset As Integer
    nFileExtension As Integer
    lpstrDefExt As String
    lCustData As Long
    lpfnHook As Long
    lpTemplateName As String
End Type
Public Function SelectFileOpenDialog()
    Dim strTemp, strTemp1, pathStr As String
    Dim i, n, j As Long
    Dim OpenFile As OPENFILENAME
    Dim lReturn As Long
    Dim sFilter As String
    Dim Fname As String
    OpenFile.lStructSize = Len(OpenFile)
    sFilter = "Assembly Files (*.iam)" & Chr(0) & "*.IAM" & Chr(0)
    OpenFile.lpstrFilter = sFilter
    OpenFile.nFilterIndex = 1
    OpenFile.lpstrFile = String(257, 0)
    OpenFile.nMaxFile = Len(OpenFile.lpstrFile) - 1
    OpenFile.lpstrFileTitle = OpenFile.lpstrFile
    OpenFile.nMaxFileTitle = OpenFile.nMaxFile
    OpenFile.lpstrInitialDir = dir_path
    OpenFile.lpstrTitle = "Select An Assembly"
    OpenFile.flags = 0
    lReturn = GetOpenFileName(OpenFile)
        If lReturn = 0 Then
    MsgBox "No file selected. Please try again."
        Else
    Fname = Trim$(OpenFile.lpstrFile)                                    ' Copies the filename to "Fname"
    n = FileLen(OpenFile.lpstrFile)                                      'Length of the file
    Resolve_and_Open.FileName.Text = Fname
        End If
End Function
 A code I use, using filesystemobject, to copy contents of a folder to another folder...
Option Explicit
Sub Folder_Testing()
    Dim path As String
        If Dir("C:\\InventorTempFolder\\\", vbDirectory) = "" Then       'Creates a new temporary directory path for a folder copy
    MkDir "C:\\InventorTempFolder\\\"
    SetAttr "C:\InventorTempFolder", vbNormal
        Else: MsgBox "Please delete the C:\InventorTempFolder and restart program."
        End If
    Dim FSO As Object
    Dim FromPath As String
    Dim ToPath As String
    FromPath = Browser.TextBox1.Text
    ToPath = "C:\\InventorTempFolder\\\"
        If Right(FromPath, 1) = "\" Then
    FromPath = Left(FromPath, Len(FromPath) - 1)
        End If
        If Right(ToPath, 1) = "\" Then
    ToPath = Left(ToPath, Len(ToPath) - 1)
        End If
    Set FSO = CreateObject("scripting.filesystemobject")
        If FSO.FolderExists(FromPath) = False Then
    MsgBox FromPath & " does not exist. Please restart process."
        Exit Sub
        End If
    FSO.CopyFolder Source:=FromPath, Destination:=ToPath                  'Copies the folder and all its files in to the new temporary directory path
End Sub
 A code I use, using filesystemobject, to delete a directory:
Option Explicit
' Delete this directory and all the files it contains.
    Sub DeletetheDirectory()
    Dim FSO
    Set FSO = CreateObject("Scripting.FileSystemObject")
    FSO.deletefolder "C:\\InventorTempFolder"
    On Error Resume Next
    End Sub
Hope this gets you on the right track!
Best Wishes,
Ali
"It's a screwdriver, not a water pistol! What are you gonna do? Construct a cabinet at them?!"
DWhiteley
Many thanks Ali, for the verbose answer.
However, what I need to be able to do is access the Filesystemobject in iLogic.
I assume a library needs to be loaded, but I don't know how to di this.
Perhaps someone out there does....
Dave
alyssaweaver
Ah okay, I'm useless then. Best of luck!!!
Best Wishes,
Ali
rjay75
In iLogic you can to get to the FileSystemObject it's ThisApplication.FileManager.FileSystemObject. However you also have access to the .NET System.IO class.
Imports SysIO = System.IO
 I use this syntax to map it to SysIO, because some parts of it can clash with the inventor api.  I use it like so, SysIO.File.Exists("afile").
DWhiteley
in reply to: rjay75
Brilliant, many thanks for your help on this.
Regards
Dave
