Following is my use case
I have a following dataset
where top level file is an assembly abcd.iam
this file refers a child part file pqrs.ipt
Structure is something like below
abcd.iam
|-->pqrs.ipt
Steps to reproduce
1) rename the pqrs.ipt file to xyz.ipt (externally via filesystem/windows explorer)
2) Launch Inventor (2011 or 2012 or 2013 or 2014)
3) Click File->Open
4) browse to the folder containing abcd.iam
5) select and open the file abcd.iam
6) Since pqrs.ipt is not found, Inventor presents with a File resolution dialog box (expected)
7) resolve/skip the file
😎 close the assembly abcd.iam
9) Now load the attached macro
10) execute procedure StartFileOpen
11) repeat steps 3-4-5
12) Inventor does not show the File resolution dialog box (ISSUE)
Expected result after Step 12 is
if file is resolved (event handled = true) then nothing should be shown
but if file is not resolved (event handled = false) then "FileResolve" Dialog should be shown
The above issue occurs only when we use Custom File Open dialog , and happens for all Inventor versions 2011, 12, 13, 14.
