We are using ApprenticeServer to read Inventor files. With Inventor 2015 we are getting error "Failed to write SATPID data to file" on Inventor part file import.This issue is reproducible with "LACIS_SAT_with_TransientKeys" format type, with "LACIS_SAT" format type the file import is working fine. We can reproduce the same in DataIOExe sample project also. Kindly share the test results at your end. I request you to guide us on this issue.
Please find attached "Arbor_Frame.ipt" file to reproduce the issue.
Monali
Hi Monali,
Yes, this is a known issue and engineering is working on a fix.
Not sure when exactly it will be available.
Sorry about the inconvenience. 😞
Cheers,
