1."FINITE ELEMENT ANALYSIS " TRIGGERING IS NOT ACCESSIBLE FROM EDIT RULE BROWSER IN THE ILOGIC RULE BOX SO AUTOMATING OR TRIGGERING FINITE ELEMENT ANALYSIS IS NOT POSSIBLE AND SECONDLY ITS ACCESSIBILITY IS ALSO NOT SHOWN IN THE LEFT SIDE UNDER THE TAB "SNIPPETS"
2.AUTOMATIC UPDATION OF PARAMETER WHICH IS LINKED TO EMBEDDED EXCEL SHEET IS NOT POSSIBLE THAT IS "UNTIL AND UNLESS UPDATE COMMAND OR UPDATE BUTTON IS NOT PRESSED INSIDE THE INVENTOR , IT IS NOT UPDATED " SO PARAMETER UPDATION SIMULTANEOUSLY IS NOT POSSIBLE
4.PARAMETER ACCESS FROM OUTSIDE THE INVENTOR IS POSSIBLE BUT ONLY IN DESCRETE LEVELS , HOW TO PERFORM RANDOM CHANGE IN PARAMETER IS NOT FOUND
3. FEA_APPLICATION_COMMON.DLL IS SHOWN PROTECTED AS SOON AS IT IS INCLUDED IN ILOGIC RULE AND ATTEMPTED TO OPEN THROUGH ILOGIC RULE BOX . IT IS ALSO NOT FOUND , WHEN INVENTOR.INTERLOP.DLL IS REFERENCED WITH VISUAL STUDIO SO THAT IT CAN BE ACCESSIBLE AND USE FOR AUTOMATIC TRIGGERING OF FEA
You want to access FEA through iLogic?
Dim oCtrlDef As ControlDefinition ' open FEA enviroment oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("FEA Environment Internal Name") oCtrlDef.Execute ' run the simulation oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("FeaSimulateCmd") oCtrlDef.Execute
And if you want to update the model after the excel sheet driving the parameters has changed, you can just call Update.
In case of iLogic it could be:
ThisDoc.Document.Update()
I'm not sure what the real question in item 3 and 4 is. Could you please clarify a bit?
Cheers,
hello sir , i am sagar and am working on developing optimisation toolbox in inventor , now what i want to do is to pass a value of parameter from , design space to the model and trigeer FEA in it and again see the value of von miss stress , displacement , mass , and decide whether value obtain from the FEA satisfies our design criterion , if not i again want to run the loop till i reach the terminsation criteria , now how should i pass a parameter value from supose matlab , to my model in inventor and perform FINITE ELEMENT ANALYSIS on it and run the loop again again till i reach optimised value or my termination criteria
i cant randomly change the value of parameter i specifeid in inventor from outside of excel or pass to inventor , , now suppose i am to pass the value from outside of the inventor simultaneously i want to perform analysis on it for that particular value of parameter and come back and check my termination criteria if it satisfies , then i can consider that particular value of parameter as a optimised value , else i have to run the loop again and check the termination condition ,
hope you understood
thanks
sagar dolas
sir tried your code in inventor , and what that code does is opens the fea module , what i want to do is setup the simulation for one time and whenever i call it , it should the perform FEA on the model , is this possible because i dont want to manually set up the FEA settings , as i mentioned in the post , i want to run the loop , and in which every time value of parameter changes , FEA is performed on it and i get the results , it this possible in INVENTOR api because i have been working on it since last 2 months abd i cannot find a automated FEA in inventor for example we can do that in ABAQUS run a loop and perform JOB on the model in every loop and append the results in a file
Unfortunately, the FEA part has no API yet, so there is no supported way of setting up the parameters, etc.
Sorry for the bad news. 😞
Cheers,
Adam
