Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Face of a Part to Workpoint in another part
6 REPLIES 6
766 Views, 6 Replies
Hello all,
what do we use to get distance from a face to a workoint in VBA??
Do we use Measuretools or Distanceto or is there anything else??
I wolud like get horizontal distance from a face to workpoint..
Please find attachment.
Look for forward for solution.
6 REPLIES 6
adam.nagy
One thing you could do is intersect the face's plane with the plane along which you want to measure, then measure the distance from the point to the intersection line:
Sub test()
    Dim ad As AssemblyDocument
    Set ad = ThisApplication.ActiveDocument
    Dim tg As TransientGeometry
    Set tg = ThisApplication.TransientGeometry
    Dim mt As MeasureTools
    Set mt = ThisApplication.MeasureTools
    ' Plane of face
    Dim p As Plane
    Set p = ad.SelectSet(1).Geometry
    ' Point from which we want to measure
    Dim pt As Point
    Set pt = ad.SelectSet(2).Point
    ' Plane inside which we want to measure
    ' Assume the plane's normal is Z
    Dim ptp As Plane
    Set ptp = tg.CreatePlane(pt, tg.CreateVector(0, 0, 1))
    Dim l As Line
    Set l = p.IntersectWithPlane(ptp)
    Dim d As Double
    d = mt.GetMinimumDistance(pt, l)
End Sub
I hope this helps.
Adam Nagy
Autodesk Platform Services
in reply to: adam.nagy
Hello Adam,
I found a way using Proxies.
Private Sub FacePoint()
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oAssyDef As AssemblyComponentDefinition
Set oAssyDef = oDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
Set oOcc = oAssyDef.occurrences.Item(1) '1) get the reference to the workpoint "2" (not origin point) in the component "1"
Dim oDef As AssemblyComponentDefinition
Set oDef = oOcc.Definition
Dim oWP As WorkPoint
Set oWP = oDef.WorkPoints.Item(2) 'create work point proxy object
Dim oWPproxy As WorkPointProxy
Call oOcc.CreateGeometryProxy(oWP, oWPproxy) '2) get the reference to the selected face
Dim oSSet As SelectSet
Set oSSet = oDoc.SelectSet
If oSSet.Count = 0 Then
MsgBox "Select some face"
Exit Sub
Dim oObj As Object
Set oObj = oSSet.Item(1)
If Not (TypeOf oObj Is FaceProxy) Then
Exit Sub
Dim oFaceProxy As FaceProxy
Set oFaceProxy = oObj '3) Measurements Dim oMeasureTools As MeasureTools
Set oMeasureTools = ThisApplication.MeasureTools
Dim D As Double ' distance (cm)
D = oMeasureTools.GetMinimumDistance(oFaceProxy, oWPproxy)
MsgBox ("D, cm = " & FormatNumber(D, 3))
End Sub 'FacePoint
Using Proxies we can get location of any feature or part.
Thanks for your reply.
AD
Accept as Solution and "Kudos" if finds useful.
Crstiano
Hi Adam,
I have a problem when use the plane on the part in the sub-assembly.
I change only this line for test :
Set p = ad.ComponentDefinition.Occurrences.Item(15).Definition.Occurrences.Item(2).Definition.WorkPlanes.Item("YZ Plane").Plane
 And the it use the "YZ Plane" from Assembly Master like reference. And not part on the sub-assembly.
Any ideia?
Cristiano Oliveira
Developer Addins | Consultant CAD/PLM | CAD Manager
https://www.ConsultCAD.com/
adam.nagy
in reply to: Crstiano
Hi Cristiano,
You go into the "Definition" of the documents so the results will be in context of the document itself and not the top assembly. The values of the "YZ Plane" of the part in context of the part is exactly the same as "YZ Plane" of the top assembly in context of the top assembly. What I think you are looking for is the values of the part's "YZ Plane" in context of the top assembly.
Please have a look at the following article. I hope it will clarify things: http://adndevblog.typepad.com/manufacturing/2013/07/occurrences-contexts-definitions-proxies.html
Cheers,
Adam Nagy
Crstiano
Hi Adam,
I set each item now, and the result is the same. Atthaced sample example.
If you use the SelectSet, ok.. fine. But if you use the "Plane", the results is wrong.
See:
Sub mytest()
    Dim addef As AssemblyComponentDefinition
     Set addef = ad.ComponentDefinition
    Dim oCC As ComponentOccurrence
     Set oCC = addef.Occurrences(1).SubOccurrences.Item(1)
    Dim part As PartDocument
     Set part = oCC.Definition.Document
    Dim partDef As PartComponentDefinition
     Set partDef = part.ComponentDefinition
    ' Plane of face
    Dim p As Plane
    Set p = partDef.WorkPlanes.Item("Plane").Plane
    'Set p = ad.SelectSet(2).Plane
    Dim pt As Point
     Set pt = ad.SelectSet(1).Point
    Dim ptp As Plane
    Dim l As Line
    Dim d As Double
End Sub
Cristiano Oliveira
Crstiano
I found the solution. Thanks for all.
Sub mytest2()
Dim oWP As WorkPlane
Set oWP = oCC.Definition.WorkPlanes.Item(1)
Dim oWPxz As WorkPlaneProxy
Call oCC.CreateGeometryProxy(oWP, oWPxz)
Dim pt As Point
Dim d As Double
d = oWPxz.Plane.DistanceTo(pt)
End Sub
Cristiano Oliveira
