I am using Inventor 2015 to create conveyor belts. These conveyors are constructed with different parameters. These can be set in a linked Excel file. When I for example change the length, width, height, angle to floor etc. in Excel, the conveyor will change into the right dimensions. It is one part, so one .ipt.
Now I make an assembly to add parts like sensors. Also shelves must be placed below the upper part of the belt. This is to avoid bending the belt as cause of heavy products. These shelves have a standard size of 1300 mm. When I have a conveyor of 5000 mm, I need 3 standard shelves of 1300 mm and one of 890 mm. The changes are rightly made with excel formulas.
The thing I was wondering about is the following: Is it possibly to extract the .ipt file name from Excel? I would like to let the partlist show something like this: 3x Shelve 1300x500 1x shelve 890x500
Looking forward to your replies,
Eduard van Leersum
