Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Extend and Trim in Inventor 2014
4 REPLIES 4
kulkary
233 Views, 4 Replies
I have two Surface bodies apart from each other (but, sort of, perpendicular, L like). How can I extend, trim and stitch them to form a single surface body.
4 REPLIES 4
YuhanZhang
in reply to: kulkary
In Inventor 2014 you can use the Combine(Part->3D Model->Modify->Combine) command to merge two solids into a single solid.
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
kulkary
in reply to: YuhanZhang
I am looking for APIs for surfaces.
philippe.leefsma
As Rocky mentioned, you can use a CombineFeature to merge solid bodies:
Sub CombineBodies()
        Dim doc As PartDocument
        Set doc = ThisApplication.ActiveDocument
        Dim def As PartComponentDefinition
        Set def = doc.ComponentDefinition
        Dim baseBody As SurfaceBody
        Set baseBody = def.SurfaceBodies(1)
        Dim toolBodies As ObjectCollection
        Set toolBodies = _
            ThisApplication.TransientObjects.CreateObjectCollection
        toolBodies.Add def.SurfaceBodies(2)
        Dim combineFeature As combineFeature
        Set combineFeature = def.features.CombineFeatures.Add( _
            baseBody, toolBodies, kCutOperation, True)
End Sub
For surfaces, you use a knit (stitch) feature. See "KnitFeatures.Add Method" in the help files.
ExtendFeature and TrimFeature creation is not exposed in the API.
I hope that helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
kulkary
in reply to: philippe.leefsma
In case of surfaces, if they are near to each other at boundaries, then it seems to work. But if one surface is perpendicular to the orher, in the middle, like letter "T", then stitching does not happen. It should trim at the intersection, create edge and then stitch. Any solution to get "T" like stitching of surfaces?
