Exsisting iLogic rule - View label fitted with Item number
Andrew2803
Andrew2803
Hi Everybody!
I have this iLogic rule below, responsible for creting Item numbers into part's view label, of an existing assembly.
My problem is: this rule creates Item number into label of projected views also, what I don't want.
How this rule should be converted to show Item numbers only in main view labels?
I have basic knowledge about iLogic.
Many thanks in advance.
Andras
' Set a reference to the drawing document.' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oSheets As Sheets
Dim Sheet As Inventor.Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
For Each oSheet In oDrawDoc.Sheets
'For Each oSheet In oSheets
    oViews = oSheet.DrawingViews
    For Each oView In oViews
        'Get the full filename Of the view model
        Dim oModelFileName As String
        oModelFileName = oView.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName
        'MessageBox.Show("view model name" & oModelFileName, "Title")
        Dim oPartList As PartsList
            'try and get the parts list form the table of this sheet
            Try
                oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
            Catch 'on error try and search all sheets for first found parts list
                'iterate trough each sheet
                Dim i As Long
                For i = 1 To oDrawDoc.Sheets.Count
                    If oDrawDoc.Sheets.Item(i).PartsLists.Count > 0 Then Exit For
                Next
                oPartList = oDrawDoc.Sheets.Item(i).PartsLists.Item(1)
                'MessageBox.Show("parts list found on: " & i, "Title")
            End Try
            ' Iterate through the contents of the parts list.
            Dim j As Long
            For j = 1 To oPartList.PartsListRows.Count
                ' Get the current row.
                Dim oRow As PartsListRow
                oRow = oPartList.PartsListRows.Item(j)
                'get filename of model in row
                Dim oRowFileName As String
                oRowFileName = oRow.ReferencedFiles.Item(1).FullFileName
                'compare the filenames
                'Performs a text comparison, based on a case-insensitive text sort order
                'If strings equal returns 0
                If StrComp(oModelFileName, oRowFileName, CompareMethod.Text)=0 Then
                    'Get the value of Item from the Parts List
                    'Row name needs to be case sensitive or use 1 for first 2 for second etc.
                    oCell  = oPartList.PartsListRows.Item(j).Item("Item") 'Row name needs to be case sensitive or use 1 for first 2 for second etc.
                    'get the value of text in cell
                    Dim oItemValue As String
                    oItemValue = oCell.Value
                    'Show the view label
                    oView.ShowLabel = True
                    'format the text first line
                    oStringItem = "<StyleOverride Underline='True' FontSize='0.35'> ITEM " & oItemValue & " </StyleOverride>"
                    'format the text second line
                    oStringScale = "<Br/><StyleOverride FontSize='0.3'>(Scale <DrawingViewScale/>)</StyleOverride>"
                    'add to the view label
                    oView.Label.FormattedText =  oStringItem & oStringScale
            Next
      Next
Next
NSBowser
Try This!  (modifications in bold)
		If oView.ViewType <> 10504 Then ' Not kProjectedDrawingViewType
			Try
				Dim i As Long
				Next
			End Try
			Dim j As Long
			Next
	Next
Next
Best of Luck
If you find this reply helpful or insightful, please use the 'Accept as Solution' or 'Kudos' button below.
Andrew2803
NSBowser!
Excellent job! Thank you!
Andrew2803
Hi NSBowser! (Or anyone else)
Could you make a second version of this code? I'd like to be able to pick different assembly's BOM lists participating on a drawing!
I guess iLogic gives option to create a dropdown menu. This menu could offer which participating assembly's BOM I want to use
spreading Itemnumbers to views of participating parts... hope this solvable this way!
Many thanks in advance!
Andras
moduseng
Is it possible to modify this rule to work with the 'part number' iProperty instead of file name?
