Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Export to PDF fails
6 REPLIES 6
Mario-Villada
889 Views, 6 Replies
Export to PDF fails
Hi there,
I have been using a macro to create PDFs from inventor drawings with the translator for many years now, I starrted in a new company and it is creating invalid PDF files. So when I try to create the PDF manually by clicking on Save copy As, I am getting this error :
   Published with a warning(s)
Cannot create font
As you can see the font has no name so I can't install any missing font.
I found out that this error occurs only in drawings created from the company template wich I believe was created years ago. If I use any other template from inventor everything is ok.
Mi first thought was that there is something wrong in any text field on the title block, but I don't know what to look for.
Does anybody knows how to fix this?
6 REPLIES 6
adam.nagy
in reply to: Mario-Villada
Would it be possible for you to post a minimal sample document that enables us to reproduce the issue?
It sounds like you can reprouce it in the UI as well, so it might be worth posting it on the Inventor Product Support forum too to see if they can comment on it.
Cheers,
Adam Nagy
Autodesk Platform Services
Mario-Villada
in reply to: adam.nagy
Thanks for your reply Adam,
I did have a response from on the othe forum. It helped soving part of the problem but still cannot get the PDF.
This was the response : RESPONSE
Thanks to Paul I fixed some problems on the text fields by changing the font, But I have also found out that there is a problem with the drawing views as well.
Please have a look a the attached file and try to save as PDF. you will see my issue.
It would be great if this can be solved since there are thousands of drawings like this one. We also detected the same problem when creating DWFs and even  Vault shows the same issue when previewing drawings.
Thanks again for your interest.
adam.nagy
I've written a blog post that I hope will be of help: http://adndevblog.typepad.com/manufacturing/2013/09/remove-illegal-text-formatting.html
Cheers,
Adam Nagy
Mario-Villada
Fantastic! this will save heaps of time!
Molly15
Hello Adam. This is the exact problem that I am having. Could you help me get this running. When I run the this code in Inventor VB is doesn't like "RegExp". I get a complie error "User-defined type not defined". Can you help.
I am on Inventor 2013 64 bit, windows 7
adam.nagy
in reply to: Molly15
Hi Molly,
You'll have to add whatever Microsoft VBScript Regular Expressions library you have:
Cheers,
Adam Nagy
