Please enable this BOM view, and save the assembly"
the detailed information of this error:
System.ArgumentException: ThisBOM: Could not find a BOM view named Structured
Please enable this BOM view, and save the assembly ---> System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.BOMViews.get_Item(Object Index)
at iLogic.CadBom.a(String A_0)
--- End of inner exception stack trace ---
Server stack trace:
at iLogic.CadBom.Export(String viewName, String fileName, FileFormatEnum fileFormat, String sheetName)
at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateProcessMessage(IntPtr md, Object[] args, Object server, Int32 methodPtr, Boolean fExecuteInContext, Object[]& outArgs)
at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProcessMessage(IMessage msg, Int32 methodPtr, Boolean fExecuteInContext)
Exception rethrown at [0]:
at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type)
at Autodesk.iLogic.Interfaces.ICadBom.Export(String viewName, String fileName, FileFormatEnum fileFormat, String sheetName)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at System.AppDomain.DoCallBack(CrossAppDomainDelegate callBackDelegate)
at Autodesk.iLogic.Exec.AppDomExec.ExecCodeInOtherDomain(AppDomain otherDomain, String assemName)
at e.a(String A_0)
I've checked if the BOM view was active and also checked the name of the bom view. We've tested it with differend assemblies and it never works.
It's only working if Your LOD is "Master"
Is this a bug in the system? Please Help
Kind regard,
Theo Bot
Do you know when this feature is going to be available?
I'm trying to get the BOM for iLogic LOD and seems impossible. Thanks
Any ideas?
