have found that I am not able to fire up event "OnRadialMarkingMenu" in Inventor 2013 in my C# addin. Inventor 2014 works correclty, but Inv2013 never fire up this event.
Code from button execution:
this.oUIEvents = this.oApp.CommandManager.UserInputEvents; this.oUIEvents.OnLinearMarkingMenu += new UserInputEventsSink_OnLinearMarkingMenuEventHandler(this.oUIEvents_OnLinearMarkingMenu); this.oUIEvents.OnRadialMarkingMenu += new Inventor.UserInputEventsSink_OnRadialMarkingMenuEventHandler(this.UIEvents_OnRadialMarkingMenu);
and events code:
void oUIEvents_OnLinearMarkingMenu(ObjectsEnumerator SelectedEntities, SelectionDeviceEnum SelectionDevice, CommandControls LinearMenu, NameValueMap AdditionalInfo) { MessageBox.Show("OnLinearMarkingMenu"); }
void UIEvents_OnRadialMarkingMenu(Inventor.ObjectsEnumerator toEntities, Inventor.SelectionDeviceEnum toSelDevice, Inventor.RadialMarkingMenu toRadialMenu, Inventor.NameValueMap toAddInfo) { MessageBox.Show("OnRadialMenu"); toRadialMenu.EastControl = oApp.CommandManager.ControlDefinitions["AppMeasureDistanceCmd"]; }
I am not sure where is problem, this doesnot work on any of our instalation, and I am not sure if this works in past (before some SP or updates instaled).
Could somebody check this?
Many thanks
Petr
Solved by philippe.leefsma. Go to Solution.
Hi Petr,
So far we do not reproduce the issue on our side. Here is the sample I used for testing:
Make sure you set the "Embedd Interop Types = False" on the Inventor.interop.dll reference in your project, setting it to true may cause issues with events.
I hope it helps.
Philippe.
thank you. I have tried it in VB.NET acc. your example and this is OK, radial menu is working. Unfortunately in C# I have not been successful. Enclosed are two my projects, first AvsTest2013 with NET 2.0 and second AvsTest with Net 4.0, both works correctly in Inventor 2014, but does not works in Inventor 2013SP2 CZ. These addins create ribbons with two buttons, button with name Test2 should start DoEvenets with RadialMenu. Projects are for VS2010 Express. Could you look to these projects?
Many thanks
Petr
The radial menu is working outside of InteractionEvents, but while selection is running it seems broken. My advice for 2013 would be to use the linear menu instead. Sorry for the bad news.
Philippe.
