I do have in Exel only one column with few Client names, and i have this rule. Guys i need you help to help me understand why this warning is up and after continue rule is working correct. What i need to fix? Thanks
myXLSX = "C:\Customer.xlsx"
GoExcel.Open(myXLSX)
ForrowNumber = 2 To 1000
If (GoExcel.CellValue("A"&rowNumber) = (""))Then
lastUsedRow = rowNumber- 1
EndIf
Next
'set the list to be read from the XLS file
DimmyArrayListAsNewArrayList
i = 2
'add the values from the Excel file to an array list
DoUntili = lastUsedRow+1
myArrayList.add(GoExcel.CellValue("A"&i))
i = i+ 1
Loop
'present the list to the user
myCust1 = InputListBox("Select Customer from list", myArrayList,myArrayList.Item(0), "iLogic", "Customer")
'set the iProperty
iProperties.Value("Summary", "Company") = myCust1
Solved by rossano_praderi. Go to Solution.
Hi, I've made few modifications to your code and now run without errors.
'myXLSX = "C:\Customer.xlsx" GoExcel.Open("C:\Customer.xlsx", "Sheet1") lastUsedRow = 2 'set the list to be read from the XLS file Dim myArrayList As New ArrayList 'add the values from the Excel file to an array list While GoExcel.CellValue("A" & lastUsedRow) <> "" myarraylist.add(GoExcel.CellValue("A" & lastUsedRow)) lastUsedRow = lastUsedRow + 1 End While 'present the list to the user myCust1 = InputListBox("Select Customer from list", myArrayList, myArrayList, Title := "iLogic", ListName := "Customer") 'set the iProperty iProperties.Value("Summary", "Company") = myCust1
Bregs
Rossano Praderi
