I am attempting to use Apprentice via Visual Basic (in Visual Studio) to access the Revision Code property for a series of drawings in Inventor 2009.
I can open an idw file via Apprentice, but then when I subsequently try to retrieve properties of the file (via its variable AppDwgDoc), I get an error "Object reference not set to an instance of an object". When I debug for more info, it says that AppDwgDoc is a "System._com" object. (As a side note, I've even tried to write this code in native VB, not using Apprentice modules, and I get the same error!)
Am I missing references, or is this a permissions thing, I tried everything I can think of with regard to these and other theories of what the problem is here.
Been on this for 2 days, please help!!
Here are the relevant lines of code:
Dim invApprentice As New Inventor.ApprenticeServerComponent <<<This opens inventor successfully. I can see it in the task manager after running this line.
Dim AppDwgDoc As Inventor.ApprenticeServerDocument
AppDwgDoc = invApprentice.Open(InventorFilename) <<<This sets AppDwgDoc to a System._Com object
Debug.Print(AppDwgDoc.FullFileName) <<<THIS IS WHERE I GET THE ERROR "null reference exception was unhandled: Object reference is not set to an instance of an object"
Here is the detailed debugging error information:
System.NullReferenceException was unhandled Message=Object reference not set to an instance of an object. Source=mscorlib StackTrace: at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData) at Inventor.ApprenticeServerDocument.get_FullFileName() at InventorIPropRevDWGUpdate.ApprenticeINV_Date.UpdateProperties(String InventorFilename) in C:\FFR_Testing\ApprenticeSampleModelRevDar\ApprenticeSample.vb:line 58 at InventorIPropRevDWGUpdate.ApprenticeINV_Date.btnProcess_Click(Object sender, EventArgs e) in C:\FFR_Testing\ApprenticeSampleModelRevDar\ApprenticeSample.vb:line 19 at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData) at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun() at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel() at Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(String[] commandLine) at InventorIPropRevDWGUpdate.My.MyApplication.Main(String[] Args) in 17d14f5c-a337-4978-8281-53493378c1071.vb:line 81 at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args) at System.Runtime.Hosting.ApplicationActivator.CreateInstance(ActivationContext activationContext, String[] activationCustomData) at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssemblyDebugInZone() at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() InnerException:
Do you get this error for any file or for the specific file only?
Are you able to open programmatically this file in Inventor ?
