EntityOne and EntityTwo in a FlushConstraint, C++
3 REPLIES 3
oransen
391 Views, 3 Replies
I can use the following C++ code to loop over the constraints in an assembly:
    for (int i = 1 ; i <= pConstraintList->Count ; i++) {
        CComPtr<AssemblyConstraint> pConstraint = nullptr ;
        pConstraintList->get_Item (CComVariant(i),&pConstraint) ;
        TRACE ("Type is %d\n",pConstraint->GetType()) ;
        CComQIPtr<FlushConstraint> pFlush (pConstraint) ;
        if (nullptr != pFlush) {
            IDispatchPtr pEnt1 = pFlush->EntityOne  ;
            IDispatchPtr pEnt2 = pFlush->EntityTwo  ;
            TRACE (L"Two parts are %p %p\n",pEnt1,pEnt2) ;
            // The question is, how to convert to PartDocument pointers???
But how do I convert from EntityOne to (for example) a PartDocument. I've experimented with all sorts of casts and conversions, but cannot get a CComPtr<PartDocument> from an IDispatchPtr
3 REPLIES 3
adam.nagy
in reply to: oransen
You cannot cast EntityOne to a PartDocument because it is a FaceProxy. Just wrote an article that should be of help:
http://adndevblog.typepad.com/manufacturing/2013/10/discover-object-model.html
Cheers,
Adam Nagy
Autodesk Platform Services
oransen
in reply to: adam.nagy
Ok, thanks for the link, now I undestand better. The 2 entities can also be WorkPlaneProxy not just FaceProxy.
I've changed my sources and can now get to the document,file, part etc like this:
        CComQIPtr<MateConstraint> pMate (pConstraint) ;
        if (nullptr != pMate) {
            IDispatchPtr pEnt1 = pMate->EntityOne  ;
            IDispatchPtr pEnt2 = pMate->EntityTwo  ;
            CComQIPtr<FaceProxy> pFace1 = CComQIPtr<FaceProxy>(pEnt1);
            CComQIPtr<WorkPlaneProxy> pWP1 = CComQIPtr<WorkPlaneProxy>(pEnt1);
            if (pFace1 != nullptr) {
                TRACE (L"  Ent1 is a face proxy...\n") ;
            } else if (pWP1 != nullptr) {
                TRACE (L"  Ent1 is a workplane proxy...\n") ;
                CComPtr<ComponentOccurrence> pContOcc = pWP1->ContainingOccurrence ;
                if (pContOcc != nullptr) {
                    CComPtr<ReferencedFileDescriptor> pFileDesc = nullptr ;
                    pContOcc->get_ReferencedFileDescriptor (&pFileDesc) ;
                    if (pFileDesc != nullptr) {
                        CComBSTR bstrFullFileName ;
                        pFileDesc->get_FullFileName (&bstrFullFileName) ;
                        TRACE (L"  Ent1 full file name is %s\n",bstrFullFileName) ;
            } else {
                TRACE (L"  Ent1 This is neither a face or workplane proxy\n") ;
Can the entities be anything else, apart from Face or WorkPlane proxies?
adam.nagy
Yes, I forgot about WorkPlane's.
Well, it would need to be something with a plane, so I think it's only face and workplane.
But if you go down the other route: Constraint > AffectedOccurrenceOne >... then it does not even matter what EntityOne is.
Cheers,
Adam Nagy
