Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Edit solid bodies color
3 REPLIES 3
TONELLAL
527 Views, 3 Replies
Is it possible, via VB, to modify solidbodies color ?
Actually, I need to modify part color. But in some cases, the part color and the solidbody color are not the same. So I need to modify the Solidbody color, to match the part color.
I found the bodies in ComponentDefinition.SurfaceBodies, but I can't find something like ComponentDefinition.SurfaceBodies.Item(1).color.
3 REPLIES 3
Dim oPartDoc As Inventor.PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    Dim oPartDef As PartComponentDefinition
    Set oPartDef = oDoc.ComponentDefinition
    Dim oBody As SurfaceBody
    Set oBody = oPartDef.SurfaceBodies.Item(1)
    Dim ors As RenderStyle
    Set ors = oPartDoc.RenderStyles.Item("RED")
    Call oBody.SetRenderStyle(kOverrideRenderStyle, ors)
 Try this
ekinsb
in reply to: TONELLAL
Public Sub SetBodyColor()
    Dim partDoc As PartDocument
    Set partDoc = ThisApplication.ActiveDocument
    Dim body As SurfaceBody
    For Each body In partDoc.ComponentDefinition.SurfaceBodies
        ' Get the Autodesk Material Library.
        Dim lib As AssetLibrary
        Set lib = ThisApplication.AssetLibraries.item("AD121259-C03E-4A1D-92D8-59A22B4807AD")
        ' Randomly generate an index for an item within the libary.
        Dim index As Long
        index = Int((lib.AppearanceAssets.Count * Rnd) + 1)
        ' Get the random appearance.
        Dim libAppearance As Asset
        Set libAppearance = lib.AppearanceAssets.item(index)
        ' Get the local version of the appearance, if it exists.
        Dim localAppearance As Asset
        On Error Resume Next
        Set localAppearance = partDoc.AppearanceAssets.item(libAppearance.Name)
        If Err.Number <> 0 Then
            ' Copy the asset into the part.
            Set localAppearance = libAppearance.CopyTo(partDoc)
        On Error GoTo 0
        ' Assign the appearance to the body.
        body.appearance = localAppearance
    Next
End Sub
The previous post will work.  The previous RenderStyle API is no longer officially supported as of Inventor 2014, but it does continue to work.  If you want to use the new appeaerances, the sample below illustrates that.
Brian Ekins
Mod the Machine blog
TONELLAL
Ok, I'll use the 1st code for 2012, then the 2nd for 2014...
Thanks for your help !
