Inventor Customization
VidarDK
Message 1 of 9 (472 Views)
Edit AutoCAD attributes
472 Views, 8 Replies
09-05-2011 05:26 AM
We have a program to update our titleblocks, the following code has worked without problems in Inventor 2010.
But in Inventor 2012, it doesn't work every time. When I insert the titleblock for the first time I can fill the attributes,
but when I want to update the titleblock, I see no change, although it has changed the values, which I can see if I manually do an edit attributes (see screenshot).
Any ideas?
Michael
    Public Shared Function SaveAutocadAttributes(ByVal intDocID As Integer, ByRef invApp As Inventor.Application) As Boolean
      Dim ht As Hashtable = AcadAttributesMapping(intDocID, invApp)
      Dim i As Integer
      Dim invDoc As DrawingDocument
      Dim acadDoc As AcadDatabase
      Dim objBlock As AcadBlock = Nothing
      Dim objAcadEntity As AcadEntity = Nothing
      Dim objAcadBlockReference As AcadBlockReference = Nothing
      Dim obj() As Object = Nothing
      Dim objAcadObject As AcadObject = Nothing
      invDoc = invApp.ActiveDocument
      acadDoc = invDoc.ContainingDWGDocument
      For Each objBlock In acadDoc.Blocks
        For Each objAcadEntity In objBlock
          If objAcadEntity.ObjectName.ToLower = "AcDbBlockReference".ToLower Then
            objAcadBlockReference = CType(objAcadEntity, AcadBlockReference)
            If objAcadBlockReference.HasAttributes Then
              Select Case objAcadBlockReference.Name
                Case "A0", "A1", "A2", "A3", "A3D", "A4", "P0", "P1", "P2", "P3", "P4"
                  obj = DirectCast(objAcadBlockReference.GetAttributes, Object())
                  For i = LBound(obj) To UBound(obj)
                    If ht.ContainsKey(obj(i).TagString) = True Then
                      obj(i).TextString = ht.Item(obj(i).TagString)
                    End If
                  Next i
              End Select
            End If
          End If
        Next
      Next
      invDoc.Update()
    End Function
The following code code works for me.
    Public Shared Sub SaveAttributes(ByVal strFieldVaule() As String, ByVal strFieldName() As String, ByRef invApp As Inventor.Application)
      Dim myBlockRef As AcadBlockReference
      Dim i As Short
      Dim h As Short
      Dim myAttributes As Object
      For Each Entity In acadDoc.PaperSpace
        If TypeOf Entity Is AcadBlockReference Then
          myBlockRef = Entity
          Select Case myBlockRef.Name
            Case "A0", "A1", "A2", "A3", "A4", "P0", "P1", "P2", "P3", "P4"
              myAttributes = Entity.GetAttributes
              For i = LBound(myAttributes) To UBound(myAttributes)
                For h = LBound(strFieldName) To UBound(strFieldName)
                  If strFieldName(h) = myAttributes(i).TagString Then
                    myAttributes(i).TextString = strFieldVaule(h)
                  End If
                Next
              Next i
          End Select
        End If
      Next
      invDoc.Update()
    End Sub
 AcadAttributesMapping was just a function that i made to put attribute values to a Hashtable.
Valued Contributor
RyanBotha
Message 2 of 9 (418 Views)
Re: Edit AutoCAD attributes
04-04-2012 12:47 AM in reply to: VidarDK
Hey Michael,
Did you ever get this to work?
What namespace does AcadAttributesMapping belong to?
Thank you
VidarDK
Message 3 of 9 (398 Views)
04-10-2012 12:51 AM in reply to: RyanBotha
      Dim i As Short
      Dim h As Short
          myBlockRef = Entity
                  End If
                Next
              Next i
          End Select
        End If
      Next
      invDoc.Update()
    End Sub
Valued Contributor
RyanBotha
Message 4 of 9 (393 Views)
04-10-2012 03:32 AM in reply to: VidarDK
What a legend! Thank you!
Valued Contributor
dave.deane
Message 5 of 9 (323 Views)
12-26-2012 04:37 AM in reply to: VidarDK
I am trying to generate some code to read an Autocad created titleblock with attributes that is in a Inventor 2013 .dwg using Visual Studio Express 2010. However, I have three references "not defined" when starting with the code above.
I have referenced the Inventor's interop library, am I missing another reference? Please see attached screenshot..
AcadBlockReference, DrawingDocument, AcadDatabase are the ones missing.
Dave
VidarDK
Message 6 of 9 (288 Views)
01-02-2013 12:04 AM in reply to: dave.deane
You have to reference
Autodesk.AutoCAD.Interop
and
Autodesk.AutoCAD.Interop.Common
Michael
Valued Contributor
dave.deane
Message 7 of 9 (275 Views)
01-02-2013 04:41 AM in reply to: VidarDK
Thank you for replying Michael but oddly enough the reference is not defined after adding in autodesk.AutoCAD.Interop and Autodesk.AutoCAD.Interop.Common. Screen shot below.
Using Visual Studio 2010 express.
Dave
VidarDK
Message 8 of 9 (268 Views)
01-02-2013 05:29 AM in reply to: dave.deane
You need to put the imports namespace names in the code as well.
Imports Autodesk.AutoCAD.Interop.Common
Valued Contributor
dave.deane
Message 9 of 9 (248 Views)
01-02-2013 10:15 AM in reply to: VidarDK
Thank you...it is working now.
Dave
Spoiler
