Afternoon All,
I have a template part with a drawing that I copy to new projects. So the part gets resized and saved as a new file, the drawing as a new file and then replace reference in the new drawing file with the new part file.
What I'm trying to do is associate a drawing dimension with an DrawingCurveSegment so I can basically look at the curve X and Y start and end locations and calculate where my drawing dimension should be moved to.
Everything works I just have no way of identifying the drawing curve after the new file save. I used the GetHashCode of the drawing curve segment but this number changes when I saved it as a new file.
Is there an attibute set or similar I can use to somehow label the DrawingCurve that I want?
