Hi
if i copy a drawing view to a new drawing and run my routine to create a partslist on "Parts Only", it works just fine but if i run the same routine on the same drawing view in an existing drawing sheet, the partslist defers to a "Structured" view.
in code, how can i force a Parts Only partslist to be created?
i have tried enabling the Parts only like this-
Dim sDoc As AssemblyDocument Set sDoc = ThisApplication.Documents.Open(omodelPath, True) Dim oBOM As bom Set oBOM = sDoc.ComponentDefinition.bom 'component definition does not work ' Make sure that the structured view is enabled. oBOM.StructuredViewEnabled = False oBOM.PartsOnlyViewEnabled = True sDoc.Save2 sDoc.Close Set sDoc = Nothing
This opens the drawing view reference and attempts to enable the BOM view but nothing works, i still get a structured parts list
Ideally, i would like to do this in the drawing sheet without opening the assembly
Nigel
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
do you use PartsLists.Add in your routine that creates a partslist in the drawing? If so, do you set the third parameter to kPartsOnly?
For example:
oSheet.PartsLists.Add(oDrawingView, oPlacementPoint, kPartsOnly)
Lubomir
