Solved by rusmwb. Go to Solution.
I realize this is an old post, but it seems to get a lot of views.
You need to create EdgeProxies since you are working in an assembly context.
After this line, oEdge1 = oObjs.Item(1)
Add
Dim oEdgeProx1 As Inventor.EdgeProxy oCompOcc.CreateGeometryProxy(oEdge1, oEdgeProx1)
Then change the line that reads; oDrawCurves = oDrawView.DrawingCurves(oEdge1)
To
oDrawCurves = oView.DrawingCurves(oEdgeProx1)
Then do the same for Edge2.
Good day Rusmwb,
Since I was searching for creating dimensions with ilogic or VBA, i come to this thread. I come with the same problem as Herrwolff came in the past, but when I see your Reply for using Proxies because we work in the Assembly context, I search in VBA-editor for Proxy, and now i am thinking: is a Drawing/DWG an Assembly-context too?
I would like to place dimensions on over 2 parts (occurrences of an Assembly) in Inventor DWG. Working with Attributes and VBA.
Hope you can explain a little bit.
Best regards,
HvanHelden
Yes you need to work with proxies in the drawing document too as well as drawing curves.
Here is a vb.net function that I have used to add general dimensions between two different parts that have a specific attribute.
Public Function AddGenDim(ByRef oSheet As Inventor.Sheet, _ ByRef oView As Inventor.DrawingView, _ ByRef oAssyDoc As Inventor.AssemblyDocument, _ ByRef Comp1occNum As Integer, _ ByRef Edge1Name As String, _ ByRef Comp2occNum As Integer, _ ByRef Edge2Name As String, _ ByRef DimOrient As String, _ ByRef DimLoc As String) As Inventor.GeneralDimension 'Get the part occurrence where the named edges are Dim oComp1occ As Inventor.ComponentOccurrence oComp1occ = oAssyDoc.ComponentDefinition.Occurrences.Item(Comp1occNum) Dim oPartDoc1 As Inventor.PartDocument oPartDoc1 = oComp1occ.Definition.Document Dim oTG As TransientGeometry oTG = _invApp.TransientGeometry 'open part in background _invApp.Documents.Open(oPartDoc1.FullFileName, False) 'Get the edges that have the attribute name Dim oObjs As ObjectCollection oObjs = oPartDoc1.AttributeManager.FindObjects("MyAttName", "MyAttName", Edge1Name) 'MsgBox("found " & oObjs.Count) Dim oEdge1 As Inventor.Edge oEdge1 = oObjs.Item(1) Dim oEdgeProx1 As Inventor.EdgeProxy = Nothing oComp1occ.CreateGeometryProxy(oEdge1, oEdgeProx1) Dim oDrawCurves As DrawingCurvesEnumerator 'oDrawCurves = oView.DrawingCurves(oEdge1) oDrawCurves = oView.DrawingCurves(oEdgeProx1) Dim oDrawCurve1 As DrawingCurve oDrawCurve1 = oDrawCurves.Item(1) Dim oPartDoc2 As Inventor.PartDocument Dim oComp2occ As Inventor.ComponentOccurrence If Comp1occNum <> Comp2occNum Then oComp2occ = oAssyDoc.ComponentDefinition.Occurrences.Item(Comp2occNum) oPartDoc2 = oComp2occ.Definition.Document If oPartDoc2.FullFileName <> oPartDoc1.FullFileName Then _invApp.Documents.Open(oPartDoc2.FullFileName, False) End If Else oComp2occ = oComp1occ oPartDoc2 = oPartDoc1 End If Dim oEdge2 As Edge oObjs = oPartDoc2.AttributeManager.FindObjects("MyAttName", "MyAttName", Edge2Name) oEdge2 = oObjs.Item(1) 'MsgBox("found " & oObjs.Count) Dim oEdgeProx2 As Inventor.EdgeProxy = Nothing oComp2occ.CreateGeometryProxy(oEdge2, oEdgeProx2) oDrawCurves = oView.DrawingCurves(oEdgeProx2) Dim oDrawCurve2 As DrawingCurve oDrawCurve2 = oDrawCurves.Item(1) Dim oDimType As DimensionTypeEnum If DimOrient = "Hor" Then oDimType = DimensionTypeEnum.kHorizontalDimensionType ElseIf DimOrient = "Ver" Then oDimType = DimensionTypeEnum.kVerticalDimensionType Else oDimType = DimensionTypeEnum.kAlignedDimensionType End If Dim MinY(3) As Double MinY(0) = oDrawCurve1.StartPoint.Y MinY(1) = oDrawCurve1.EndPoint.Y MinY(2) = oDrawCurve2.StartPoint.Y MinY(3) = oDrawCurve2.EndPoint.Y Dim MinX(3) As Double MinX(0) = oDrawCurve1.StartPoint.X MinX(1) = oDrawCurve1.EndPoint.X MinX(2) = oDrawCurve2.StartPoint.X MinX(3) = oDrawCurve2.EndPoint.X Dim oPlaceDimX As Double = 0 Dim oPlaceDimY As Double = 0 'Horizontal and Below If DimOrient = "Hor" Then oPlaceDimX = (oDrawCurve1.StartPoint.X + oDrawCurve2.StartPoint.X) / 2 If DimLoc = "Below" Then oPlaceDimY = MinY.Min - 0.5 ElseIf DimLoc = "Above" Then oPlaceDimY = MinY.Min + 0.5 End If ElseIf DimOrient = "Ver" Then oPlaceDimY = (oDrawCurve1.StartPoint.Y + oDrawCurve2.StartPoint.Y) / 2 If DimLoc = "Left" Then oPlaceDimX = MinX.Min - 0.5 ElseIf DimLoc = "Right" Then oPlaceDimX = MinX.Min + 0.5 End If End If Dim oPT As Point2d oPT = oTG.CreatePoint2d(oPlaceDimX, oPlaceDimY) 'create dimensions Dim oGeneralDims As GeneralDimensions oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions Dim oDim As GeneralDimension oDim = oGeneralDims.AddLinear( oPT, oSheet.CreateGeometryIntent(oDrawCurve1), oSheet.CreateGeometryIntent(oDrawCurve2), oDimType) oPartDoc1.Close(False) If Comp2occNum <> Comp1occNum Then oPartDoc2.Close(False) End If Return oDim End Function
Here is the call to that function that you would make in the sub routine
Dim oWidthDim As GeneralDimension oWidthDim = AddGenDim(oSheet, oFaceView, oAssyDoc, 1, "RightEdge", 1, "LeftEdge", "Hor", "Below")
The code I provided was from a vb.net application. VBA is a little bit different which is why you are getting some syntax errors. Do a little research on the differences between vb.net and vba as well as proxies and you should be able to resolve it.
Hello all!
That VBA and iLogic works nice, and rusmwb code and reply works really nice!
But i have an problem with 1 kind of dimension to place. In this message-attatchment you can find an package with drawing, assembly and parts like i have to dimension. In the JPG's you can see the settings from the attributes. The flat sides of the shaft must be dimensioned, but it doesn´t work.
I make an iLogic rule for creating dimension on the block, wich wil work fine! (Dimension from 1 part to another will work to! But in this assembly I haven't built in it.)
Copy that for dimensioning the shaft-flats, and it doesn't work; an H-result-Exception-error come up.
Then I add an color-changer for the searched shaft-edges (drawingcurves) to see or iLogic see the 'right' edges; and yes; exact the edges needed for creation the dimension are changed their color!! (press UNDO 2times for original settings.)
So I am looking for what I am doing wrong.
Could someone help me out of this?
The bug is specially on the line: "Set oDim = oGeneralDims.AddLinear(oPlaceDim1, oSheet.CreateGeometryIntent(oDrawCurve1), oSheet.CreateGeometryIntent(oDrawCurve2), oDimType)", and when I use Parameter Info (CTRL+SHIFT+D); I see the IntentTwo is not followed with 'as Geometry Intent', like IntentOne, and in square brackets. Why?
The commented lines in the rule maybe could explain you enouch for what I am doing in the rule; but for short: in the first section you see an declaration of the file, and dimension-specific parameters (Attributes+position) are given ONLY in that second section; (the only section wich cannot be collapsed).
In VBA editor you see the wrong rule translated under Module1 from the drawing file; maybe you could find the bug faster trough that workspace.
The rule is mostly from rusmwb, thanks! But all others on internet thanks for all the stuff.
Hopefully someone could help me; thanks in advance!!
Greetz, and have a nice day!
HvanHelden
VBA-code:
Sub ShaftFlat() '[============= Algemene declaratie ============= Dim invApp As Application Set invApp = ThisApplication ' Get the Active Drawing document Dim oDrawDoc As Inventor.DrawingDocument Set oDrawDoc = invApp.ActiveDocument ' Get the active sheet Dim oSheet As Sheet Set oSheet = oDrawDoc.ActiveSheet ' Get the just DrawingView Dim oView As DrawingView Set oView = oSheet.DrawingViews.Item(1) 'Debug.Print oView.Name ' Get reference to document from wich the drawingview is made Dim oAssyDoc As Inventor.AssemblyDocument Set oAssyDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument ' Get all Components Dim oOccurrences As ComponentOccurrences Set oOccurrences = oAssyDoc.ComponentDefinition.Occurrences '] ''' BETWEEN THIS LINE AND NEXT GREEN LINE, YOU COULD GIVE THE INFORMATION FOR PLACE THE DIMENSION YOU WANT TO CREATE!!! ' Set number of Occurrence1 in Assembly-tree Dim Comp1occNum As Integer Comp1occNum = 2 ' Set number of Occurrence2 in Assembly-tree Dim Comp2occNum As Integer Comp2occNum = 2 'Gives the Attribute-information for searching the right ' Set attribute-1-style; for select Face or Edge-proxies and geometries Dim AttStyle1 As String AttStyle1 = "Face" 'or: "Edge" ' Set attribute-1-value Dim AttSet1 As String AttSet1 = "ShaftFlat1" ' Set attribute-1-value Dim AttName1 As String AttName1 = "ShaftFlat1" ' Set attribute-1-value Dim AttValue1 As String AttValue1 = "1" ' Set attribute-2-style; for select Face or Edge-proxies and geometries Dim AttStyle2 As String AttStyle2 = "Face" 'or: "Edge" ' Set attribute-2-value Dim AttSet2 As String AttSet2 = "ShaftFlat2" ' Set attribute-2-value Dim AttName2 As String AttName2 = "ShaftFlat2" ' Set attribute-2-value Dim AttValue2 As String AttValue2 = "2" 'Set X- and Y-position of dimenion-line and text: Dim DimPlaceX As Double '=4 omdat het schaal 1:2 is, =10 omdat hij in [cm] ipv. [mm] werkt DimPlaceX = (oView.Left + oView.Width / 2) Dim DimPlaceY As Double DimPlaceY = (oView.Top - (oView.Height / 2)) ''' END OF EDITING ZONE FOR CREATING DIMENSIONS YOU WANT TO CREATE !!! '''' Ready's code for create aligned dimension '''Dim DimOrient As String '''Dim DimLoc As String '[======================= Take edges of part1 ================================== '----------------------- ---------------------------------- 'Get the occurrence-PARTFILE where the named attributes are Dim oComp1occ As Inventor.ComponentOccurrence Set oComp1occ = oAssyDoc.ComponentDefinition.Occurrences.Item(Comp1occNum) 'Set reference to that file Dim oPartDoc1 As Inventor.PartDocument Set oPartDoc1 = oComp1occ.Definition.Document 'Open part in background Dim oPartDoc As Inventor.Document Set oPartDoc = invApp.Documents.Open(oPartDoc1.FullFileName, False) 'Get the objects that have the attribute-name Dim oObjs As ObjectCollection Set oObjs = oPartDoc1.AttributeManager.FindObjects(AttSet1, AttName1, AttValue1) 'MsgBox ("Found Attribute-objects in AttributeSet1: " & oObjs.Count) 'Declare oDrawCurves to place a curve in Dim oDrawCurves As DrawingCurvesEnumerator 'Search right Attribute-1-style, for create right proxies. 'When attribute-1 lies on a 'face': If AttStyle1 = "Face" Then 'Set Face where Attribute-1 lies Dim oFace1 As Inventor.Face Set oFace1 = oObjs.Item(1) 'Make Face-GeometryProxy for geometry translation in from Part to DWG or Assembly. Dim oFaceProx1 As Inventor.FaceProxy oComp1occ.CreateGeometryProxy oFace1, oFaceProx1 'Take DrawingView-Drawcurves from the Face-GeometryProxy Set oDrawCurves = oView.DrawingCurves(oFaceProx1) Debug.Print ("Found Faces in proxy-1: " & oDrawCurves.Count) 'MsgBox ("Found Faces in proxy-1: " & oDrawCurves.Count) 'When attribute lies on a 'edge': ElseIf AttStyle1 = "Edge" Then 'Set Edge where Attribute-1 lies Dim oEdge1 As Inventor.Edge Set oEdge1 = oObjs.Item(1) 'Make Edge-GeometryProxy for geometry translation in from Part to DWG or Assembly. Dim oEdgeProx1 As Inventor.EdgeProxy oComp1occ.CreateGeometryProxy oEdge1, oEdgeProx1 'Take DrawingView-Drawcurves from the Edge-GeometryProxy Set oDrawCurves = oView.DrawingCurves(oEdgeProx1) 'MsgBox ("Found Edges in proxy-1: " & oDrawCurves.Count) End If 'Take the first item (I think in this case there are no more than one item!) Dim oDrawCurve1 As DrawingCurve Set oDrawCurve1 = oDrawCurves.Item(1) '] '[======================= Take edges of part2 ================================== '----------------------- ---------------------------------- 'Get the occurrence-PARTFILE where the named attributes are Dim oPartDoc2 As Inventor.PartDocument Dim oComp2occ As Inventor.ComponentOccurrence 'When occ.numbers not the same, set occurrence-PARTFILE-2 If Comp1occNum <> Comp2occNum Then Set oComp2occ = oAssyDoc.ComponentDefinition.Occurrences.Item(Comp2occNum) Set oPartDoc2 = oComp2occ.Definition.Document 'When PARTFILE-2 is not the same as PARTFILE-1, then open PARTFILE-2 in the background If oPartDoc2.FullFileName <> oPartDoc1.FullFileName Then Set oPartDoc = invApp.Documents.Open(oPartDoc2.FullFileName, False) End If 'When occ.numbers the same, set occurrence-PARTFILE-2 = occurrence-PARTFILE-1 Else Set oComp2occ = oComp1occ Set oPartDoc2 = oPartDoc1 End If 'Get the objects that have the attribute-name Dim oObjs2 As ObjectCollection Set oObjs2 = oPartDoc2.AttributeManager.FindObjects(AttSet2, AttName2, AttValue2) 'MsgBox ("Found Attribute-objects in AttributeSet2: " & oObjs2.Count) 'Search right Attribute-2-style, for create right proxies. 'When attribute-2 lies on a 'face': If AttStyle2 = "Face" Then 'Set Face where Attribute-2 lies Dim oFace2 As Inventor.Face Set oFace2 = oObjs2.Item(1) 'Make Face-GeometryProxy for geometry translation in from Part to DWG or Assembly. Dim oFaceProx2 As Inventor.FaceProxy oComp2occ.CreateGeometryProxy oFace2, oFaceProx2 'Take DrawingView-Drawcurves from the Face-GeometryProxy Set oDrawCurves = oView.DrawingCurves(oFaceProx2) Debug.Print ("Found Faces in proxy-2: " & oDrawCurves.Count) 'MsgBox ("Found Faces in proxy-2: " & oDrawCurves.Count) 'When attribute-2 lies on a 'edge': ElseIf AttStyle2 = "Edge" Then 'Set Edge where Attribute-2 lies Dim oEdge2 As Inventor.Edge Set oEdge2 = oObjs2.Item(1) 'Make Edge-GeometryProxy for geometry translation in from Part to DWG or Assembly. Dim oEdgeProx2 As Inventor.EdgeProxy oComp2occ.CreateGeometryProxy oEdge2, oEdgeProx2 'Take DrawingView-Drawcurves from the Edge-GeometryProxy Set oDrawCurves = oView.DrawingCurves(oEdgeProx2) 'MsgBox ("Found Edges in proxy-2: " & oDrawCurves.Count) End If 'Take the first item (I think in this case there are no more than one item!) Dim oDrawCurve2 As DrawingCurve Set oDrawCurve2 = oDrawCurves.Item(1) '] '[================ Make TransientGeometry and place dimension ================ Dim oDimType As DimensionTypeEnum If DimOrient = "Hor" Then oDimType = DimensionTypeEnum.kHorizontalDimensionType '60162 ElseIf DimOrient = "Ver" Then oDimType = DimensionTypeEnum.kVerticalDimensionType '60163 Else oDimType = DimensionTypeEnum.kAlignedDimensionType '60161 End If ' Ready's code for TransientGeometry, needed for working with X,Y coordinates in Sheet Dim oTG As TransientGeometry Set oTG = ThisApplication.TransientGeometry Dim oPlaceDim1 As Point2d Set oPlaceDim1 = oTG.CreatePoint2d(DimPlaceX, DimPlaceY) 'Create dimensions Dim oGeneralDims As GeneralDimensions Set oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions Debug.Print ("Existing dimensions: " & oGeneralDims.Count) Dim oDim As GeneralDimension Set oDim = oGeneralDims.AddLinear(oPlaceDim1, oSheet.CreateGeometryIntent(oDrawCurve1), oSheet.CreateGeometryIntent(oDrawCurve2), oDimType) Dim oDim1Att As AttributeSet Set oDim1Att = oDim.AttributeSets.Add("ilogic_Created") oPartDoc1.Close (False) If Comp2occNum <> Comp1occNum Then oPartDoc2.Close (False) End If '] End Sub
I found your post extremely helpful. Thankyou.
I have also been trying to get a method of autodimensioing which uses workplanes in a single skeletal part (which drives my assembly) instead of faces or edges, but seem to be having little success referencing the workplane proxies with the drawing curves.
I tried to update the following coding used in the following rule to point to a part within the assembly shown on the drawing & use
2 workplane attributes Ihad set on workplanes in the part.
'---INITIAL SETUP--------- 'References this document Dim oDrawDoc As DrawingDocument oDrawDoc = ThisDoc.Document 'References this drawing sheet Dim oSheet As Sheet oSheet = oDrawDoc.ActiveSheet 'References this drawing view Dim oView As DrawingView oView = ActiveSheet.View("VIEW").View 'References this drawing view model Dim oAssyDoc As AssemblyDocument oAssyDoc = ActiveSheet.View("VIEW").ModelDocument 'Readys code for Creation of reference points for dimension placement Dim oTG As TransientGeometry oTG = ThisApplication.TransientGeometry 'Readys code for creation of general dimensions Dim oGeneralDims As GeneralDimensions oGeneralDims = oSheet.DrawingDimensions.GeneralDimensions '---DIMENSION PREP------------ 'finds edges with a particular attributes then taks the first instance Dim aoEdge4 as face oObjs = oAssyDoc.AttributeManager.FindObjects("ATTRIBUTE SET", "ATTRIBUTE", "VARIABLE") aoEdge4 = oObjs.Item(1) 'finds edges with a particular attributes then taks the first instance Dim aoEdge3 as face oObjs = oAssyDoc.AttributeManager.FindObjects("ATTRIBUTE SET", "ATTRIBUTE", "VARIABLE'') aoEdge3 = oObjs.Item(1) 'Finds the drawing edge that represents the one with the attribute Dim aoDrawCurves4 As DrawingCurve oDrawViewCurves = oView.DrawingCurves(aoEdge4) aoDrawCurves4 = oDrawViewCurves.Item(1) ' 'Finds the drawing edge that represents the one with the attribute Dim aoDrawCurves3 As DrawingCurve oDrawViewCurves = oView.DrawingCurves(aoEdge3) aoDrawCurves3 = oDrawViewCurves.Item(1) ' Dim oPt2 As Point2d oPt2 = oTG.CreatePoint2d(oView.Left + (oView.Width/2 ),oView.Top - (oView.Height) - 1) ' '---CREATING DIMENSIONS------------ ' Dim oDim2 As GeneralDimension oDim2 = oGeneralDims.AddLinear(oPt2, oSheet.CreateGeometryIntent(aoDrawCurves3), oSheet.CreateGeometryIntent(aoDrawCurves4)) 'oDim2.text.FormattedText = oDim2.text.FormattedText & " OVERALL INTERNAL LENGTH " Dim oDim2Att As AttributeSet ODim2Att = oDim2.AttributeSets.Add("ilogic_Created")
Any assiatnce would be truly appreciated.
Regards
Wayne
Hi Wayne,
I haven't gotten too deep in this but it seems that the these lines of code would find the same object (face) rather than two different ones.
Dim aoEdge4 as face
Dim aoEdge3 as face
Yes. But It does seem to work - for example like this.
Were you referring to this reference : "oObjs.Item(1)" which is the same for both edges?
Dim aoEdge4 as face
oObjs = oAssyDoc.AttributeManager.FindObjects("SIDEA", "A_DIM", "1")
Dim aoEdge3 as face
oObjs = oAssyDoc.AttributeManager.FindObjects("SIDEB", "B_DIM", "1'')
I have also since discovered - that I cannot use WorkPlaneProxies for calling these auto dimensions on a drawing
because I can only attach to Faces, Sketches, Bodies etc, so I am using a surfaceface (instead of a plane) which I can turn off in the drawing view without losing my dimension.
Thanks very much for your response. Much appreciated.
Wayne
Dim oSheet As Sheet
oView = ActiveSheet.View("VIEW4").View
oAssyDoc = ActiveSheet.View("VIEW4").ModelDocument
'Reference the first Sub-part in my assembly shown in the Drawing View (1) or (2) or so on
Dim occ As ComponentOccurrence
occ = oAssyDoc.ComponentDefinition.Occurrences.Item(1)
'I only used this to check I was referencing the right Sub-part in my assembly shown in the drawing view
If occ.Name = "YourSubPartName:1" Then
MessageBox.Show(occ.Name, "Title")
'You can also put your auto dim rule here if you only want the AutoDims run if this sub-part exists
End If
Dim aoEdge4 As Face
oObjs = occ.Definition.Document.AttributeManager.FindObjects("SURFACE1", "DIMP1", "1")
occ.CreateGeometryProxy(oObjs.Item(1), aoEdge4)
Dim aoEdge3 As Face
oObjs = occ.Definition.Document.AttributeManager.FindObjects("SURFACE2", "DIMP2", "1")
occ.CreateGeometryProxy(oObjs.Item(1), aoEdge3)
Dim aoDrawCurves1 As DrawingCurve
Dim aoDrawCurves2 As DrawingCurve
Dim oPt2 As Point2d
‘DELETE AUTO DIMENSION - USE THIS IN A SEPARATE RULE TO REMOVE Any of the above AutoDimensions
Dim oDoc as DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Inventor.Sheet
oSheet = oDoc.ActiveSheet
Dim oDim as DrawingDimension
For Each oDim in oSheet.DrawingDimensions
If oDim.AttributeSets.Nameisused("ilogic_Created") = True Then
oDim.Delete
End If
Next
