Dear,
I got a macro job for creation the drawing for a part. I got a lot of problem.
1/ The first one is move view:
I already create a view (e.g. oIsoView), now I want to move it to the left.
I find the DrawingView.Position method, how can I use this method? I try many time, but it's not successful yet.
Do I need to use the SelectSet method??????
Solved by YuhanZhang. Go to Solution.
Dim pSymbl as string
pSymbl = "Ø"
Dim pGenDims As GeneralDimensions
pGenDims = .DrawingDimensions.GeneralDimensions
Dim pCnt As Integer
pCnt = pGenDims.Count ''Get the latest count of the dimension & edit the dimension immediatly after creation
pGenDims.Item(pCnt).Text.FormattedText = pSymbl & "<DimensionValue/>"
Please Accept as solution if you got succeeded.
