Inventor Customization
Employee
yuhanzhang
Message 11 of 20 (1,093 Views)
Re: Drawing Automation with VBA
04-24-2011 08:49 PM in reply to: nttoan8187
You can use AIGDT font to the FormattedText to show symbols:
<StyleOverride Font='AIGDT' Bold='False'>n</StyleOverride>
Rocky Zhang
Inventor API
Manufacturing Solutions
Valued Contributor
nttoan8187
Message 12 of 20 (1,088 Views)
04-24-2011 09:44 PM in reply to: yuhanzhang
Amazing!
Could you please give me the materials for some special symbol in Format Text? I cannot find out where I can read them.
For instance: DimensionValue, SectionViewName, etc........
I got a problem in dimension that is I cannot use GeneralDimensions.AddLinear to dimension between a centerline and a line curve
'oCLine100 is the center line, oLCurve100 is the line curve. Two lines is parallel. oDimPos is the point 2d
Dim oGI100, oGI101 As GeometryIntent
Set oGI100 = oSheet.CreateGeometryIntent(oLCurve100)
Set oGI101 = oSheet.CreateGeometryIntent(oCLine100)
Dim oLDim100 As LinearGeneralDimension
Set oLDim100 = oSheet.DrawingDimensions.GeneralDimensions.AddLinear(oDimPos100, oGI100, oGI101, kDiametricDimensionType)
Please help me to figure out what goes wrong in the code????
This GeneralDimensions.AddLinear() is really terrible. It make my Inventor crash down more than 15 time per day........... although I use "On Error Resume Next" before the code line or not.
Please mark this answer as Problem Solved if it solves your question.
Toan
Inventor API
Valued Contributor
nttoan8187
Message 13 of 20 (1,084 Views)
04-25-2011 12:19 AM in reply to: nttoan8187
Sometimes, the problem shows out like this following figure:
But sometimes, Inventor crash down like this
For average 30 minutes for one crash like this. If I use the GeneralDimensions.AddLinear 3 or 4 times, it crash down immediately.
Autodesk men, please check out, I am tired of crash and reopen Inventor and crash and reopen..................................so annoyed
If you can find out the solution, please make the hot-fix for it!!!!!!!!!!!
Toan
Inventor API
Employee
yuhanzhang
Message 14 of 20 (1,081 Views)
04-25-2011 01:34 AM in reply to: nttoan8187
In API help, you can search the topic titled "XML Tags for FormattedText" to understand more details about FomattedText.
Can you attach a data to reproduce the failure for adding the diametric linear dimension?
Rocky Zhang
Inventor API
Valued Contributor
nttoan8187
Message 15 of 20 (1,078 Views)
04-25-2011 02:27 AM in reply to: yuhanzhang
Sorry, but it is the company properties, I don't have the permission to attach.......
But I really DO NOT understand why.
First,
I change the code to dimension for two line segment curves, which is only different in Y position, every else is same.
Then I create the Center Line by two kStartPoint of two lines, it worked
This means that these two GeometryIntent are right. Then the AddLinear() not work with these two GeometryIntent
If I don't create CenterLine AddLinear also didn't work!!!!!!! Run two or three time, Inventor crashs down........
---> Unbelievable
Then, I change to the most simple case. I get two geometry intent that is the StartPoint and EndPoint of a line curve.
AddLinear didn't work too. What happens??????????
Do you believe this?????
In two case, I change the color and weight of curves, and it work well---> this means that the curves is not nothing and they are right!
So, assuming that I don't understand and I write wrong code?????? Why Inventor crashes??????????? Today, I got more than 20 crashes, it is really irritated.
I know that this sounds stupid, but it was. Now I will try to make a sample to test and send for you........
Toan
Inventor API
Valued Contributor
nttoan8187
Message 16 of 20 (1,074 Views)
04-25-2011 03:05 AM in reply to: nttoan8187
I just create a simple test, it can work, and the List of Properties/Methods can work also
In my macro, even I press Ctrl+J, it not work??????
Or the wrong thing happens because my code is too long???????????????
About 3000 lines and will be 5000 lines if I can use AddLinear to dimension the drawing..................
How I can solve this problem???? Please help!!!!
Toan
Inventor API
Employee
yuhanzhang
Message 17 of 20 (1,075 Views)
04-25-2011 03:49 AM in reply to: nttoan8187
If the data is protected, can you create another simple sample  to reproduce the issue which you think is safe to attach? Or you can try to select a line segment curve on a drawing, and then run below VBA code to check if it works:
Sub CreateLinearDiametricDim()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oCurve As DrawingCurve
    Set oCurve = oDoc.SelectSet(1).Parent
    Dim oIntent1 As GeometryIntent, oIntent2 As GeometryIntent
    Set oIntent1 = oDoc.ActiveSheet.CreateGeometryIntent(oCurve, kStartPointIntent)
    Set oIntent2 = oDoc.ActiveSheet.CreateGeometryIntent(oCurve, kEndPointIntent)
    Dim oDim As LinearGeneralDimension
    Dim oPt As Point2d
    Set oPt = ThisApplication.TransientGeometry.CreatePoint2d(12, 12)
    Set oDim = oDoc.ActiveSheet.DrawingDimensions.GeneralDimensions.AddLinear(oPt, oIntent1, oIntent2, kDiametricDimensionType)
End Sub
As the issue for display the List of Properties/Methods, can you check if there are two subs which have the same name in the module/class?
Rocky Zhang
Inventor API
Valued Contributor
nttoan8187
Message 18 of 20 (1,059 Views)
04-26-2011 02:41 AM in reply to: yuhanzhang
I just think to new solution that doesn't need to dimension automatic by VBA anymore.
Maybe in my next project, we will discuss more. Thank you so much!
I have a question about DrawingView:
How I can Delete the oBaseView but still exist the oIsoView????
If we do this manually, we can choose No when a prompt appear and ask us to Delete Projected Views or not
But I don't see any option in DrawingView.Delete() method.
Toan
Inventor API
Valued Contributor
nttoan8187
Message 19 of 20 (1,048 Views)
04-26-2011 07:01 PM in reply to: nttoan8187
Sorry for me,
I just try and only the obaseview is deleted; the isoview still be there. It's no need to do anything else, thanks IV for this!
Toan
Inventor API
Distinguished Contributor
sergelachance
Message 20 of 20 (390 Views)
08-08-2013 03:04 AM in reply to: yuhanzhang
Hi nttoan8187
I'm not really good with ilogic, maybe you can help me?
I just want to create a automatique isoview of my base you with ilogic, do you have a idea for the rule?
Thanks for your help :smileyhappy:
