Hi everyone,
I am using inventor for the first time and I need a little bit of help. I am trying to make a toilet paper roller; standard white ones with the spring inside (http://www.homedepot.ca/wcsstore/HomeDepotCanada/images/catalog/15449.M5690_4.jpg) .
I need to cut the bottom of the cylinder at a 45 degree angle from the center to wall so if the roller was standing, it would be at an angle of 45 degrees to.
I have attatched what I have so far.,
I am having trouble with the slicing. I am not sure how to chop the whole cylnder at an angle; i'd like to cut off the plane. Cut everything from one side of the plane, the smaller side. The angle I want is of the plane.
Also how do I remove the yellow lines and the white line with the measurement .1280 (you'll understand when you open the file)
Thanks, I really appreciate any help.
