I try to move, by translation, an arrow of a leader but my code doing nothing.
My code:
Dim oDrawDoc As Inventor.DrawingDocument
oDrawDoc = oApp.ActiveDocument
Dim oSheets As Inventor.Sheets
oSheets = oDrawDoc.Sheets
Dim oSheet As Inventor.Sheet
oSheet = oSheets(1)
Dim oTG As Inventor.TransientGeometry
oTG = oApp.TransientGeometry
Dim oBalloon As Inventor.Balloon
Dim index As Integer
For index = 1 To oSheet.Balloons.Count
Dim oTranslation As Inventor.Vector2d
oTranslation = oTG.CreateVector2d(20, 20)
oBalloon = oSheet.Balloons(index)
Dim oArrowPosition as Inventor.Point2d
oArrowPosition = oBalloon.Leader.AllLeafNodes(1).Position
oArrowPosition.TranslateBy(oTranslation)
Next
oSheet.Update()
Thanks for help.
Pascal
Solved by planglais75. Go to Solution.
Ok, I found my answer: use CreatePoint2d method instead of CreateVector2D of TransientGeometry:
Dim oNewPosition As Inventor.Vector2d
oNewPosition = oTG.CreatePoint2d(20, 20)
Dim oArrow as Inventor.LeaderNode
oArrow = oBalloon.Leader.AllLeafNodes(1)
oArrow.Position = oNewPosition
