Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Dockable Window Help Button
6 REPLIES 6
rjay75
874 Views, 6 Replies
Is there a way to customize the action or target of the help button in a dockable window?
6 REPLIES 6
philippe.leefsma
in reply to: rjay75
Hi Rodney,
Did you look at "DockableWindowsEvents.OnHelp Event", this should allow you to perform custom action when the dockable window help button is hit by user.
Philippe.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
rjay75
in reply to: philippe.leefsma
rjay75
Is there an example of this anywhere. I have wired up the OnHelp event but it doesn't seem to ever fire.
ekinsb
in reply to: rjay75
Attached is a simple C# program that demonstrates creating a dockable window and handling the OnShow, OnHide, and OnHelp events for the window.  It's a minimal set of code but hopefully it's fairly obvious from here what you need to do in the event handlers.
Brian Ekins
Mod the Machine blog
GeorgK
in reply to: ekinsb
Is there a sample for Vb.Net? I tried to convert it to VB.Net but it does not run. Thank you. Georg
philippe.leefsma
in reply to: GeorgK
Here is a VB.Net sample:
http://adndevblog.typepad.com/manufacturing/2012/06/embedding-a-wpf-user-control-in-a-dockablewindow...
Philippe.
Philippe Leefsma
