How do you divide a segment equally with a range in visual basic?
example-
length is 144 in
range- 7.5 - 9in
answer- (18) at (range 8 in)
like to know how to do this in Visual Basic so I can create some rules and forms in iLogic
thx
Hi there,
There are loads of ways to do this. Here is one:
Sub Demo() Dim Length As Double Dim Range As Double Length = 144 Range = 8 MsgBox (Answer(Length, Range)) End Sub Function Answer(L As Double, R As Double) Answer = L / R End Function
This should be a start for you
Cheers
Jon.
Yes, it's not difficult, but can be tricky and frustrating! Parameters can be pretty fickle when it comes to units.
If you have:
d0 = Length (in)
d1 = Range (in)
d2 = Answer/Segments (ul)
Note that the inch units cancel each other to give a unitless value (in/in = ul).
Cheers
Jon.
