Inventor Customization
heyjude19
Message 1 of 4 (134 Views)
Divide a segment equally with a range in visual basic
134 Views, 3 Replies
01-15-2013 05:44 PM
How do you divide a segment equally with a range in visual basic?
example-
length is 144 in
range- 7.5 - 9in
answer- (18) at (range 8 in)
like to know how to do this in Visual Basic so I can create some rules and forms in iLogic
thx
Hi there,
There are loads of ways to do this. Here is one:
Sub Demo()
Dim Length As Double
Dim Range As Double
Length = 144
Range = 8
MsgBox (Answer(Length, Range))
End Sub
Function Answer(L As Double, R As Double)
Answer = L / R
End Function
This should be a start for you
Cheers
Jon.
Valued Contributor
jonbrabbs
Message 2 of 4 (127 Views)
Re: Divide a segment equally with a range in visual basic
01-15-2013 11:48 PM in reply to: heyjude19
Hi there,
Sub Demo()
Dim Range As Double
    Length = 144
    Range = 8
End Sub
    Answer = L / R
End Function
Cheers
Jon.
If this post helps you, please give kudos.
heyjude19
Message 3 of 4 (120 Views)
01-16-2013 04:34 AM in reply to: jonbrabbs
Thanks Jon
- can this be done within the parameters instead of iLogic?
Valued Contributor
jonbrabbs
Message 4 of 4 (113 Views)
01-16-2013 06:55 AM in reply to: heyjude19
Yes, it's not difficult, but can be tricky and frustrating! Parameters can be pretty fickle when it comes to units.
If you have:
d0 = Length (in)
d1 = Range (in)
d2 = Answer/Segments (ul)
Note that the inch units cancel each other to give a unitless value (in/in = ul).
Cheers
Jon.
