I am trying to create a command to display the bend information in the model Flat pattern. We do not always create a Idw for parts that we have special dies to form. This creates a problem though if the flat pattern bends are the wrong direction because then it is lasered with the bad side of the material to the outside of the part. The only way to know the bend direction is to create a view on an idw just to check this.
I want to open the flat pattern in the ipt and invoke a command to display the bend information on the screen. Has anyone done this or at least point me in the direction of getting a collection of the bend lines in the flat pattern?
Scott A. McCoy
West-Mark Tank
Solved by smccoywm. Go to Solution.
I too would enjoy knowing the answer!
Here is my solution. I added it to my Inventor Add-In creating a button in the Flat Pattern Ribbon. It's probably not the cleanest approach but it works well.
Private Sub oButton_Bends_OnExecute(ByVal Context As Inventor.NameValueMap) Handles oButton_Bens.OnExecute oInteractionEvents = Inv.CommandManager.CreateInteractionEvents oInteractionEvents.StatusBarText = "Press Esc to Cancel command." oInteractionEvents.Start() Dim i As Integer = 1 ' Set a reference to the active document. Dim oPartDoc As PartDocument oPartDoc = Inv.ActiveDocument ' Set a reference to the active flat pattern. Dim oFlatPattern As FlatPattern oFlatPattern = Inv.ActiveEditObject Dim oAllBendEdges As EdgeCollection oAllBendEdges = Inv.TransientObjects.CreateEdgeCollection Dim oTempEdge As Edge ' Highlight tangent edges in blue. Dim oTangentHS As HighlightSet oTangentHS = Inv.ActiveDocument.CreateHighlightSet oTangentHS.Color = Inv.TransientObjects.CreateColor(255, 0, 0) On Error Resume Next Call FlatPatternInformation() If Err.Number Then Err.Clear() ' Get all Bend UP edges on top face Dim oTopFaceBendUpEdges As Edges oTopFaceBendUpEdges = oFlatPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge, True) For Each oTempEdge In oTopFaceBendUpEdges Call AddText(i, "UP", (oTempEdge.StartVertex.Point.X + oTempEdge.StopVertex.Point.X) / 2, (oTempEdge.StartVertex.Point.Y + oTempEdge.StopVertex.Point.Y) / 2) i += 1 Next ' Highlight tangent edges in blue. Dim oTangentHS2 As HighlightSet oTangentHS2 = Inv.ActiveDocument.CreateHighlightSet oTangentHS2.Color = Inv.TransientObjects.CreateColor(0, 0, 255) ' Get all Bend DOWN edges on top face Dim oTopFaceBendDownEdges As Edges oTopFaceBendDownEdges = oFlatPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge, True) For Each oTempEdge In oTopFaceBendDownEdges Call AddText(i, "DN", (oTempEdge.StartVertex.Point.X + oTempEdge.StopVertex.Point.X) / 2, (oTempEdge.StartVertex.Point.Y + oTempEdge.StopVertex.Point.Y) / 2) i += 1 Next ' Get all Bend UP edges on top face oTopFaceBendUpEdges = oFlatPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge, True) For Each oTempEdge In oTopFaceBendUpEdges oAllBendEdges.Add(oTempEdge) oTangentHS.AddItem(oTempEdge) Next ' Get all Bend DOWN edges on top face oTopFaceBendDownEdges = oFlatPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge, True) For Each oTempEdge In oTopFaceBendDownEdges oAllBendEdges.Add(oTempEdge) oTangentHS2.AddItem(oTempEdge) Next Inv.ActiveView.Update() End Sub Private Sub AddText(ByRef Instance As Integer, ByRef Direction As String, ByRef x As Integer, ByRef y As Integer, Optional ByVal LJustify As Boolean = False) Dim oClientGraphics As ClientGraphics oClientGraphics = Inv.ActiveEditObject.ClientGraphicsCollection.Add("Bend" & Instance) ' Create a graphics node. Dim oNode As GraphicsNode oNode = oClientGraphics.AddNode(1) ' Create text graphics. Dim oTextGraphics As TextGraphics oTextGraphics = oNode.AddTextGraphics ' Set the properties of the text. oTextGraphics.Text = Direction oTextGraphics.Bold = False oTextGraphics.Font = "Arial" oTextGraphics.FontSize = 18 oTextGraphics.Italic = False Call oTextGraphics.PutTextColor(255, 255, 0) oTextGraphics.VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextLower If LJustify = True Then ' Set the properties of the text. oTextGraphics.Anchor = Inv.TransientGeometry.CreatePoint(x, y, 0) oTextGraphics.HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft Else ' Set the properties of the text. oTextGraphics.Anchor = Inv.TransientGeometry.CreatePoint(x, y, 0) oTextGraphics.HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextCenter End If End Sub Public Sub FlatPatternInformation() Dim oDoc As PartDocument oDoc = Inv.ActiveDocument Dim SpaceX As Integer = 200 Dim SpaceY As Integer = 10 Dim Interiorprofiles As String Dim Perimeter As String Dim strThickness As String Dim strMaterial As String Dim oExtent As Inventor.Box Dim dLength As Double Dim dWidth As Double Dim sLength As String Dim sWidth As String Dim oFlatPattern As Inventor.FlatPattern oFlatPattern = oDoc.ComponentDefinition.FlatPattern Perimeter = FlatPatternGetTotalLength(oDoc) Interiorprofiles = FlatPatternGetInteriorLoopCount(oDoc) strMaterial = oDoc.ComponentDefinition.Material.Name ' Get a reference to the parameter controlling the thickness. Dim oThicknessParam As Inventor.Parameter oThicknessParam = oDoc.ComponentDefinition.Thickness strThickness = oThicknessParam.Expression oExtent = oFlatPattern.Body.RangeBox ' Extract the width and length from the range. dLength = System.Math.Round(oExtent.MaxPoint.X, 2) - System.Math.Round(oExtent.MinPoint.X, 2) dWidth = System.Math.Round(oExtent.MaxPoint.Y, 2) - System.Math.Round(oExtent.MinPoint.Y, 2) Dim oUom As Inventor.UnitsOfMeasure oUom = oDoc.UnitsOfMeasure sWidth = oUom.GetStringFromValue(dWidth, Inventor.UnitsTypeEnum.kDefaultDisplayLengthUnits) sLength = oUom.GetStringFromValue(dLength, Inventor.UnitsTypeEnum.kDefaultDisplayLengthUnits) ' Set a reference to the component definition. Dim oCompDef As ComponentDefinition oCompDef = oDoc.ComponentDefinition ' Attempt to get the existing client graphics object. If it exists ' delete it so the rest of the code can continue as if it never existed. Dim oClientGraphics As ClientGraphics ' Create a new ClientGraphics object. oClientGraphics = Inv.ActiveEditObject.ClientGraphicsCollection.Add("Flat Information") ' Create a graphics node. Dim oNode As GraphicsNode oNode = oClientGraphics.AddNode(1) Dim oTG As TransientGeometry oTG = Inv.TransientGeometry Dim oModelAnchorPoint As Inventor.Point If dLength > dWidth * 2 Then oModelAnchorPoint = oTG.CreatePoint(oExtent.MinPoint.X, oExtent.MinPoint.Y - 6, 0) Else oModelAnchorPoint = oTG.CreatePoint(oExtent.MaxPoint.X + 6, oExtent.MaxPoint.Y, 0) End If ' Create several text graphics objects, one for each font change. The anchor of the ' TextGraphics object defines the position of each text element relative to each other. ' Because they're all drawn with pixel scaling behavior these coordinates are in ' pixel SpaceX. They all use the same point as input for the SetTransformBehavior call. ' This point is in model SpaceX and defines their anchor within the model. ' Draw the first character which is the diameter symbol. Dim oTextGraphics(0 To 12) As TextGraphics oTextGraphics(1) = oNode.AddTextGraphics oTextGraphics(1).Text = "Thickness: " oTextGraphics(1).Anchor = oTG.CreatePoint(oModelAnchorPoint.X, oModelAnchorPoint.Y, 0) oTextGraphics(1).Font = "ARIAL" oTextGraphics(1).FontSize = 18 oTextGraphics(1).Bold = True oTextGraphics(1).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft Call oTextGraphics(1).PutTextColor(255, 255, 0) oTextGraphics(1).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper Call oTextGraphics(1).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling) oTextGraphics(2) = oNode.AddTextGraphics oTextGraphics(2).Text = strThickness oTextGraphics(2).Anchor = oTG.CreatePoint(oModelAnchorPoint.X + SpaceX, oModelAnchorPoint.Y, 0) oTextGraphics(2).Font = "ARIAL" oTextGraphics(2).FontSize = 18 oTextGraphics(2).Bold = True oTextGraphics(2).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextRight Call oTextGraphics(2).PutTextColor(255, 255, 0) oTextGraphics(2).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper Call oTextGraphics(2).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling) ' Draw the next section of the string relative to the first section. oTextGraphics(3) = oNode.AddTextGraphics oTextGraphics(3).Text = "Material: " oTextGraphics(3).Anchor = oTG.CreatePoint(oModelAnchorPoint.X, oModelAnchorPoint.Y - SpaceY * 2, 0) oTextGraphics(3).Font = "Arial" oTextGraphics(3).FontSize = 18 oTextGraphics(3).Bold = True oTextGraphics(3).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft Call oTextGraphics(3).PutTextColor(255, 255, 0) oTextGraphics(3).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper Call oTextGraphics(3).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling) oTextGraphics(4) = oNode.AddTextGraphics oTextGraphics(4).Text = strMaterial oTextGraphics(4).Anchor = oTG.CreatePoint(oModelAnchorPoint.X + SpaceX, oModelAnchorPoint.Y - SpaceY * 2, 0) oTextGraphics(4).Font = "ARIAL" oTextGraphics(4).FontSize = 18 oTextGraphics(4).Bold = True oTextGraphics(4).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextRight Call oTextGraphics(4).PutTextColor(255, 255, 0) oTextGraphics(4).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper Call oTextGraphics(4).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling) ' Draw a depth symbol on the next line. oTextGraphics(5) = oNode.AddTextGraphics oTextGraphics(5).Text = "Perimeter: " oTextGraphics(5).Anchor = oTG.CreatePoint(oModelAnchorPoint.X, oModelAnchorPoint.Y - SpaceY * 4, 0) oTextGraphics(5).Font = "Arial" oTextGraphics(5).FontSize = 18 oTextGraphics(5).Bold = True oTextGraphics(5).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft Call oTextGraphics(5).PutTextColor(255, 255, 0) oTextGraphics(5).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper Call oTextGraphics(5).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling) oTextGraphics(6) = oNode.AddTextGraphics oTextGraphics(6).Text = Perimeter oTextGraphics(6).Anchor = oTG.CreatePoint(oModelAnchorPoint.X + SpaceX, oModelAnchorPoint.Y - SpaceY * 4, 0) oTextGraphics(6).Font = "ARIAL" oTextGraphics(6).FontSize = 18 oTextGraphics(6).Bold = True oTextGraphics(6).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextRight Call oTextGraphics(6).PutTextColor(255, 255, 0) oTextGraphics(6).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper Call oTextGraphics(6).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling) ' Draw the last set of text.s oTextGraphics(7) = oNode.AddTextGraphics oTextGraphics(7).Text = "Interior Profiles: " oTextGraphics(7).Anchor = oTG.CreatePoint(oModelAnchorPoint.X, oModelAnchorPoint.Y - SpaceY * 6, 0) oTextGraphics(7).Font = "Arial" oTextGraphics(7).FontSize = 18 oTextGraphics(7).Bold = True oTextGraphics(7).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft Call oTextGraphics(7).PutTextColor(255, 255, 0) oTextGraphics(7).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper Call oTextGraphics(7).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling) oTextGraphics(8) = oNode.AddTextGraphics oTextGraphics(8).Text = Interiorprofiles oTextGraphics(8).Anchor = oTG.CreatePoint(oModelAnchorPoint.X + SpaceX, oModelAnchorPoint.Y - SpaceY * 6, 0) oTextGraphics(8).Font = "ARIAL" oTextGraphics(8).FontSize = 18 oTextGraphics(8).Bold = True oTextGraphics(8).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextRight Call oTextGraphics(8).PutTextColor(255, 255, 0) oTextGraphics(8).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper Call oTextGraphics(8).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling) ' Draw the last set of text.s oTextGraphics(9) = oNode.AddTextGraphics oTextGraphics(9).Text = "Max X Dim: " oTextGraphics(9).Anchor = oTG.CreatePoint(oModelAnchorPoint.X, oModelAnchorPoint.Y - SpaceY * 8, 0) oTextGraphics(9).Font = "Arial" oTextGraphics(9).FontSize = 18 oTextGraphics(9).Bold = True oTextGraphics(9).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft Call oTextGraphics(9).PutTextColor(255, 255, 0) oTextGraphics(9).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper Call oTextGraphics(9).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling) oTextGraphics(10) = oNode.AddTextGraphics oTextGraphics(10).Text = sLength oTextGraphics(10).Anchor = oTG.CreatePoint(oModelAnchorPoint.X + SpaceX, oModelAnchorPoint.Y - SpaceY * 8, 0) oTextGraphics(10).Font = "ARIAL" oTextGraphics(10).FontSize = 18 oTextGraphics(10).Bold = True oTextGraphics(10).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextRight Call oTextGraphics(10).PutTextColor(255, 255, 0) oTextGraphics(10).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper Call oTextGraphics(10).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling) ' Draw the last set of text.s oTextGraphics(11) = oNode.AddTextGraphics oTextGraphics(11).Text = "Max Y Dim: " oTextGraphics(11).Anchor = oTG.CreatePoint(oModelAnchorPoint.X, oModelAnchorPoint.Y - SpaceY * 10, 0) oTextGraphics(11).Font = "Arial" oTextGraphics(11).FontSize = 18 oTextGraphics(11).Bold = True oTextGraphics(11).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft Call oTextGraphics(11).PutTextColor(255, 255, 0) oTextGraphics(11).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper Call oTextGraphics(11).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling) oTextGraphics(12) = oNode.AddTextGraphics oTextGraphics(12).Text = sWidth oTextGraphics(12).Anchor = oTG.CreatePoint(oModelAnchorPoint.X + SpaceX, oModelAnchorPoint.Y - SpaceY * 10, 0) oTextGraphics(12).Font = "ARIAL" oTextGraphics(12).FontSize = 18 oTextGraphics(12).Bold = True oTextGraphics(12).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextRight Call oTextGraphics(12).PutTextColor(255, 255, 0) oTextGraphics(12).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper Call oTextGraphics(12).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling) ' Update the view to see the text. Inv.ActiveView.Update() 'Inv.ActiveView.Fit(True) End Sub Private Sub oInteractionEvents_OnTerminate() Handles oInteractionEvents.OnTerminate Dim oClientGraphics As ClientGraphics For Each oClientGraphics In Inv.ActiveEditObject.ClientGraphicsCollection oClientGraphics.Delete() Next Inv.ActiveView.Update() End Sub
Sounds like I could use this. BUt I'm confused. Is this a VBA macro (I copied/pasted but can't get it to load) or am I missing something?
