Display Bend Direction in Model Flat pattern
7 REPLIES 7
Message 1 of 8
smccoywm
1316 Views, 7 Replies
I am trying to create a command to display the bend information in the model Flat pattern. We do not always create a Idw for parts that we have special dies to form. This creates a problem though if the flat pattern bends are the wrong direction because then it is lasered with the bad side of the material to the outside of the part. The only way to know the bend direction is to create a view on an idw just to check this.
I want to open the flat pattern in the ipt and invoke a command to display the bend information on the screen. Has anyone done this or at least point me in the direction of getting a collection of the bend lines in the flat pattern?
Scott A. McCoy
West-Mark Tank
7 REPLIES 7
Message 2 of 8
smccoywm
in reply to: smccoywm
Nevermind I found the answer I was looking for and developed a solution.
Message 3 of 8
alewer
Care to share your solution? I was hoping that somebody would come up with the answer, as it would help me too.
Message 4 of 8
MegaJerk
in reply to: alewer
I too would enjoy knowing the answer!
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Message 5 of 8
smccoywm
 Here is my solution. I added it to my Inventor Add-In creating a button in the Flat Pattern Ribbon. It's probably not the cleanest approach but it works well. Smiley Happy
        Private Sub oButton_Bends_OnExecute(ByVal Context As Inventor.NameValueMap) Handles oButton_Bens.OnExecute
            oInteractionEvents = Inv.CommandManager.CreateInteractionEvents
            oInteractionEvents.StatusBarText = "Press Esc to Cancel command."
            oInteractionEvents.Start()
            Dim i As Integer = 1
            ' Set a reference to the active document.
            Dim oPartDoc As PartDocument
            oPartDoc = Inv.ActiveDocument
            ' Set a reference to the active flat pattern.
            Dim oFlatPattern As FlatPattern
            oFlatPattern = Inv.ActiveEditObject
            Dim oAllBendEdges As EdgeCollection
            oAllBendEdges = Inv.TransientObjects.CreateEdgeCollection
            Dim oTempEdge As Edge
            ' Highlight tangent edges in blue.
            Dim oTangentHS As HighlightSet
            oTangentHS = Inv.ActiveDocument.CreateHighlightSet
            oTangentHS.Color = Inv.TransientObjects.CreateColor(255, 0, 0)
            On Error Resume Next
            Call FlatPatternInformation()
            If Err.Number Then Err.Clear()
            ' Get all Bend UP edges on top face
            Dim oTopFaceBendUpEdges As Edges
            oTopFaceBendUpEdges = oFlatPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendUpFlatPatternEdge, True)
            For Each oTempEdge In oTopFaceBendUpEdges
                Call AddText(i, "UP", (oTempEdge.StartVertex.Point.X + oTempEdge.StopVertex.Point.X) / 2, (oTempEdge.StartVertex.Point.Y + oTempEdge.StopVertex.Point.Y) / 2)
                i += 1
            Next
            Dim oTangentHS2 As HighlightSet
            oTangentHS2 = Inv.ActiveDocument.CreateHighlightSet
            oTangentHS2.Color = Inv.TransientObjects.CreateColor(0, 0, 255)
            ' Get all Bend DOWN edges on top face
            Dim oTopFaceBendDownEdges As Edges
            oTopFaceBendDownEdges = oFlatPattern.GetEdgesOfType(FlatPatternEdgeTypeEnum.kBendDownFlatPatternEdge, True)
            For Each oTempEdge In oTopFaceBendDownEdges
                Call AddText(i, "DN", (oTempEdge.StartVertex.Point.X + oTempEdge.StopVertex.Point.X) / 2, (oTempEdge.StartVertex.Point.Y + oTempEdge.StopVertex.Point.Y) / 2)
                i += 1
            Next
                oAllBendEdges.Add(oTempEdge)
                oTangentHS.AddItem(oTempEdge)
            Next
                oTangentHS2.AddItem(oTempEdge)
            Next
            Inv.ActiveView.Update()
        End Sub
        Private Sub AddText(ByRef Instance As Integer, ByRef Direction As String, ByRef x As Integer, ByRef y As Integer, Optional ByVal LJustify As Boolean = False)
            Dim oClientGraphics As ClientGraphics
            oClientGraphics = Inv.ActiveEditObject.ClientGraphicsCollection.Add("Bend" & Instance)
            ' Create a graphics node.
            Dim oNode As GraphicsNode
            oNode = oClientGraphics.AddNode(1)
            ' Create text graphics.
            Dim oTextGraphics As TextGraphics
            oTextGraphics = oNode.AddTextGraphics
            ' Set the properties of the text.
            oTextGraphics.Text = Direction
            oTextGraphics.Bold = False
            oTextGraphics.Font = "Arial"
            oTextGraphics.FontSize = 18
            oTextGraphics.Italic = False
            Call oTextGraphics.PutTextColor(255, 255, 0)
            oTextGraphics.VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextLower
            If LJustify = True Then
                oTextGraphics.Anchor = Inv.TransientGeometry.CreatePoint(x, y, 0)
                oTextGraphics.HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft
            Else
                oTextGraphics.HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextCenter
            End If
        End Sub
        Public Sub FlatPatternInformation()
            Dim oDoc As PartDocument
            oDoc = Inv.ActiveDocument
            Dim SpaceX As Integer = 200
            Dim SpaceY As Integer = 10
            Dim Interiorprofiles As String
            Dim Perimeter As String
            Dim strThickness As String
            Dim strMaterial As String
            Dim oExtent As Inventor.Box
            Dim dLength As Double
            Dim dWidth As Double
            Dim sLength As String
            Dim sWidth As String
            Dim oFlatPattern As Inventor.FlatPattern
            oFlatPattern = oDoc.ComponentDefinition.FlatPattern
            Perimeter = FlatPatternGetTotalLength(oDoc)
            Interiorprofiles = FlatPatternGetInteriorLoopCount(oDoc)
            strMaterial = oDoc.ComponentDefinition.Material.Name
            ' Get a reference to the parameter controlling the thickness.
            Dim oThicknessParam As Inventor.Parameter
            oThicknessParam = oDoc.ComponentDefinition.Thickness
            strThickness = oThicknessParam.Expression
            oExtent = oFlatPattern.Body.RangeBox
            ' Extract the width and length from the range.
            dLength = System.Math.Round(oExtent.MaxPoint.X, 2) - System.Math.Round(oExtent.MinPoint.X, 2)
            dWidth = System.Math.Round(oExtent.MaxPoint.Y, 2) - System.Math.Round(oExtent.MinPoint.Y, 2)
            Dim oUom As Inventor.UnitsOfMeasure
            oUom = oDoc.UnitsOfMeasure
            sWidth = oUom.GetStringFromValue(dWidth, Inventor.UnitsTypeEnum.kDefaultDisplayLengthUnits)
            sLength = oUom.GetStringFromValue(dLength, Inventor.UnitsTypeEnum.kDefaultDisplayLengthUnits)
            ' Set a reference to the component definition.
            Dim oCompDef As ComponentDefinition
            oCompDef = oDoc.ComponentDefinition
            ' Attempt to get the existing client graphics object.  If it exists
            ' delete it so the rest of the code can continue as if it never existed.
            ' Create a new ClientGraphics object.
            oClientGraphics = Inv.ActiveEditObject.ClientGraphicsCollection.Add("Flat Information")
            Dim oTG As TransientGeometry
            oTG = Inv.TransientGeometry
            Dim oModelAnchorPoint As Inventor.Point
            If dLength > dWidth * 2 Then
                oModelAnchorPoint = oTG.CreatePoint(oExtent.MinPoint.X, oExtent.MinPoint.Y - 6, 0)
            Else
                oModelAnchorPoint = oTG.CreatePoint(oExtent.MaxPoint.X + 6, oExtent.MaxPoint.Y, 0)
            End If
            ' Create several text graphics objects, one for each font change.  The anchor of the
            ' TextGraphics object defines the position of each text element relative to each other.
            ' Because they're all drawn with pixel scaling behavior these coordinates are in
            ' pixel SpaceX.  They all use the same point as input for the SetTransformBehavior call.
            ' This point is in model SpaceX and defines their anchor within the model.
            ' Draw the first character which is the diameter symbol.
            Dim oTextGraphics(0 To 12) As TextGraphics
            oTextGraphics(1) = oNode.AddTextGraphics
            oTextGraphics(1).Text = "Thickness: "
            oTextGraphics(1).Anchor = oTG.CreatePoint(oModelAnchorPoint.X, oModelAnchorPoint.Y, 0)
            oTextGraphics(1).Font = "ARIAL"
            oTextGraphics(1).FontSize = 18
            oTextGraphics(1).Bold = True
            oTextGraphics(1).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft
            Call oTextGraphics(1).PutTextColor(255, 255, 0)
            oTextGraphics(1).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper
            Call oTextGraphics(1).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling)
            oTextGraphics(2) = oNode.AddTextGraphics
            oTextGraphics(2).Text = strThickness
            oTextGraphics(2).Anchor = oTG.CreatePoint(oModelAnchorPoint.X + SpaceX, oModelAnchorPoint.Y, 0)
            oTextGraphics(2).Font = "ARIAL"
            oTextGraphics(2).FontSize = 18
            oTextGraphics(2).Bold = True
            oTextGraphics(2).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextRight
            Call oTextGraphics(2).PutTextColor(255, 255, 0)
            oTextGraphics(2).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper
            Call oTextGraphics(2).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling)
            ' Draw the next section of the string relative to the first section.
            oTextGraphics(3) = oNode.AddTextGraphics
            oTextGraphics(3).Text = "Material: "
            oTextGraphics(3).Anchor = oTG.CreatePoint(oModelAnchorPoint.X, oModelAnchorPoint.Y - SpaceY * 2, 0)
            oTextGraphics(3).Font = "Arial"
            oTextGraphics(3).FontSize = 18
            oTextGraphics(3).Bold = True
            oTextGraphics(3).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft
            Call oTextGraphics(3).PutTextColor(255, 255, 0)
            oTextGraphics(3).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper
            Call oTextGraphics(3).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling)
            oTextGraphics(4) = oNode.AddTextGraphics
            oTextGraphics(4).Text = strMaterial
            oTextGraphics(4).Anchor = oTG.CreatePoint(oModelAnchorPoint.X + SpaceX, oModelAnchorPoint.Y - SpaceY * 2, 0)
            oTextGraphics(4).Font = "ARIAL"
            oTextGraphics(4).FontSize = 18
            oTextGraphics(4).Bold = True
            oTextGraphics(4).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextRight
            Call oTextGraphics(4).PutTextColor(255, 255, 0)
            oTextGraphics(4).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper
            Call oTextGraphics(4).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling)
            ' Draw a depth symbol on the next line.
            oTextGraphics(5) = oNode.AddTextGraphics
            oTextGraphics(5).Text = "Perimeter: "
            oTextGraphics(5).Anchor = oTG.CreatePoint(oModelAnchorPoint.X, oModelAnchorPoint.Y - SpaceY * 4, 0)
            oTextGraphics(5).Font = "Arial"
            oTextGraphics(5).FontSize = 18
            oTextGraphics(5).Bold = True
            oTextGraphics(5).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft
            Call oTextGraphics(5).PutTextColor(255, 255, 0)
            oTextGraphics(5).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper
            Call oTextGraphics(5).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling)
            oTextGraphics(6) = oNode.AddTextGraphics
            oTextGraphics(6).Text = Perimeter
            oTextGraphics(6).Anchor = oTG.CreatePoint(oModelAnchorPoint.X + SpaceX, oModelAnchorPoint.Y - SpaceY * 4, 0)
            oTextGraphics(6).Font = "ARIAL"
            oTextGraphics(6).FontSize = 18
            oTextGraphics(6).Bold = True
            oTextGraphics(6).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextRight
            Call oTextGraphics(6).PutTextColor(255, 255, 0)
            oTextGraphics(6).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper
            Call oTextGraphics(6).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling)
            ' Draw the last set of text.s
            oTextGraphics(7) = oNode.AddTextGraphics
            oTextGraphics(7).Text = "Interior Profiles: "
            oTextGraphics(7).Anchor = oTG.CreatePoint(oModelAnchorPoint.X, oModelAnchorPoint.Y - SpaceY * 6, 0)
            oTextGraphics(7).Font = "Arial"
            oTextGraphics(7).FontSize = 18
            oTextGraphics(7).Bold = True
            oTextGraphics(7).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft
            Call oTextGraphics(7).PutTextColor(255, 255, 0)
            oTextGraphics(7).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper
            Call oTextGraphics(7).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling)
            oTextGraphics(8) = oNode.AddTextGraphics
            oTextGraphics(8).Text = Interiorprofiles
            oTextGraphics(8).Anchor = oTG.CreatePoint(oModelAnchorPoint.X + SpaceX, oModelAnchorPoint.Y - SpaceY * 6, 0)
            oTextGraphics(8).Font = "ARIAL"
            oTextGraphics(8).FontSize = 18
            oTextGraphics(8).Bold = True
            oTextGraphics(8).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextRight
            Call oTextGraphics(8).PutTextColor(255, 255, 0)
            oTextGraphics(8).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper
            Call oTextGraphics(8).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling)
            oTextGraphics(9) = oNode.AddTextGraphics
            oTextGraphics(9).Text = "Max X Dim: "
            oTextGraphics(9).Anchor = oTG.CreatePoint(oModelAnchorPoint.X, oModelAnchorPoint.Y - SpaceY * 8, 0)
            oTextGraphics(9).Font = "Arial"
            oTextGraphics(9).FontSize = 18
            oTextGraphics(9).Bold = True
            oTextGraphics(9).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft
            Call oTextGraphics(9).PutTextColor(255, 255, 0)
            oTextGraphics(9).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper
            Call oTextGraphics(9).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling)
            oTextGraphics(10) = oNode.AddTextGraphics
            oTextGraphics(10).Text = sLength
            oTextGraphics(10).Anchor = oTG.CreatePoint(oModelAnchorPoint.X + SpaceX, oModelAnchorPoint.Y - SpaceY * 8, 0)
            oTextGraphics(10).Font = "ARIAL"
            oTextGraphics(10).FontSize = 18
            oTextGraphics(10).Bold = True
            oTextGraphics(10).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextRight
            Call oTextGraphics(10).PutTextColor(255, 255, 0)
            oTextGraphics(10).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper
            Call oTextGraphics(10).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling)
            oTextGraphics(11) = oNode.AddTextGraphics
            oTextGraphics(11).Text = "Max Y Dim: "
            oTextGraphics(11).Anchor = oTG.CreatePoint(oModelAnchorPoint.X, oModelAnchorPoint.Y - SpaceY * 10, 0)
            oTextGraphics(11).Font = "Arial"
            oTextGraphics(11).FontSize = 18
            oTextGraphics(11).Bold = True
            oTextGraphics(11).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextLeft
            Call oTextGraphics(11).PutTextColor(255, 255, 0)
            oTextGraphics(11).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper
            Call oTextGraphics(11).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling)
            oTextGraphics(12) = oNode.AddTextGraphics
            oTextGraphics(12).Text = sWidth
            oTextGraphics(12).Anchor = oTG.CreatePoint(oModelAnchorPoint.X + SpaceX, oModelAnchorPoint.Y - SpaceY * 10, 0)
            oTextGraphics(12).Font = "ARIAL"
            oTextGraphics(12).FontSize = 18
            oTextGraphics(12).Bold = True
            oTextGraphics(12).HorizontalAlignment = HorizontalTextAlignmentEnum.kAlignTextRight
            Call oTextGraphics(12).PutTextColor(255, 255, 0)
            oTextGraphics(12).VerticalAlignment = VerticalTextAlignmentEnum.kAlignTextUpper
            Call oTextGraphics(12).SetTransformBehavior(oModelAnchorPoint, DisplayTransformBehaviorEnum.kFrontFacingAndPixelScaling)
            ' Update the view to see the text.
            'Inv.ActiveView.Fit(True)
        End Sub
        Private Sub oInteractionEvents_OnTerminate() Handles oInteractionEvents.OnTerminate
            For Each oClientGraphics In Inv.ActiveEditObject.ClientGraphicsCollection
                oClientGraphics.Delete()
            Next
        End Sub
Message 6 of 8
alewer
Thanks!
Message 7 of 8
Sounds like I could use this. BUt I'm confused. Is this a VBA macro (I copied/pasted but can't get it to load) or am I missing something?
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 8 of 8
This is VB.net. I wrote it to be added to a VB.net add-in.
