My question is when I use GoExcel.CellValue (or other similar Excel link) snippet in iLoggic to write on a Excel sheet, I get a save prompt for the respective Excel file.
i.e.
GoExcel.CellValue ("WB1.xls", "Sheet1", "A1") = 1234
(Run Rule)
(I get a message box saying)
"Do you want to save the changes you made to "WB1.xls?"
Yes / No / Cancel
How can i bypass this message, I would prefer it is can be done through the iLogic Rule?
WajihHassan
Solved by Curtis_Waguespack. Go to Solution.
Solved by mrattray. Go to Solution.
If you put an auto save on close sub into the excel sheet then you wont have this problem.
Thanks Mike.
I am not sure how to put an AutoSave?
I have a GoExcel.Save snippet.
But what should I do in case of more than one Excel file,
Also, I do not want to save one of them (as it contains some predefined formulas)
Hi WHassan,
I think you can use this:
excelApp.DisplayAlerts = false
There is an example of it in use here:
I hope this helps.
Curtis
