Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Dialog on OnSaveDocument
1 REPLY 1
348 Views, 1 Reply
I try to open a Form that i create in the OnSaveDocument Event. I tested the Event with some MessageBox, they show up succesfully.
The Problem, My Form does not show on Screen.
        Private Sub m_appEvents_OnSaveDocument(ByVal DocumentObject As Inventor.Document, ByVal BeforeOrAfter As Inventor.EventTimingEnum, ByVal Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) _
                                  Handles m_appEvents.OnSaveDocument
            If BeforeOrAfter = EventTimingEnum.kBefore Then
                If DocumentObject.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or DocumentObject.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
                    CheckCustomiProperty(DocumentObject, "Name englisch", "")
                    CheckCustomiProperty(DocumentObject, "BENKEY", "")
                    Dim oUDProps As PropertySet
                    oUDProps = DocumentObject.PropertySets.Item(4)
                    Dim oProps As PropertySet
                    oProps = DocumentObject.PropertySets.Item(3)
                    If oUDProps.Item("Name englisch").Value = ""
                        MsgBox(oUDProps.Item("Name englisch").Value)
                        MsgBox(oUDProps.Item("BENKEY").Value)
                        MsgBox(oProps.Item(2).Value)
                        MyForm.Show()
                        MyForm.TopMost = True
        End Sub
The Important Part is:
'WORKS
'DONT WORK
                        MyForm.Show()
 Thank you for your help, is it possible to show the Dialog ?
Best Regards Mathias
1 REPLY 1
Vladimir.Ananyev
I think you need to make Inventor the parent for your form.
Will you please look into this discussion:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Can-t-tab-through-Add-in-form/m-p/2528...
 Here is the source text of WindowWrapper class provided by Josh_Petitt
    ''' <summary>
    ''' Used to wrap a Win32 hWnd as a .Net IWind32Window class.
    ''' This is primarily used for parenting a dialog to the Inventor window.
    ''' </summary>
    ''' <remarks>
    ''' For example:
    ''' myForm.Show(New WindowWrapper(m_inventorApplication.MainFrameHWND))
    ''' </remarks>
    Public Class WindowWrapper
        Implements System.Windows.Forms.IWin32Window
        Public Sub New(ByVal handle As IntPtr)
            _hwnd = handle
        End Sub
        Public ReadOnly Property Handle() As IntPtr _
          Implements System.Windows.Forms.IWin32Window.Handle
            Get
                Return _hwnd
            End Get
        End Property
        Private _hwnd As IntPtr
    End Class
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
