Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
DesignViewRepresentation Object
3 REPLIES 3
DWhiteley
323 Views, 3 Replies
Am I able to use the DesignViewRepresentation Object from the API in a part file, now that parts have design views.
I want to use the API to create a new design view in a part.
Dave
Envisage
3 REPLIES 3
Hi Dave,
Did you try "RepresentationsManager.DesignViewRepresentations.Add" ?
This returns a DesignViewRepresentation object and you can then set its properties. Please take a look at the help files for more details on DesignViewRepresentation object.
Hope this helps,
Philippe
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Thanks  Philippe & this works with parts as well as assemblies?
Dave
yes I was quickly testing, it seems to work fine for both:
Public Sub addViewRep()
    Dim doc As Document
    Set doc = ThisApplication.ActiveDocument
    Dim compDef As ComponentDefinition
    Set compDef = doc.ComponentDefinition
    Dim rep As DesignViewRepresentation
    Set rep = compDef.RepresentationsManager.DesignViewRepresentations.Add
End Sub
Philippe Leefsma
