I am experiencing a rather strange "error" issue. Mostly, the errors are from design center files (XML I believe). When I begin new assembly files (for example) I get multiple error messages for "part list". It seems that these errors affect me when trying to use custom part bubbles in drawings. I will have to elaborate later ... the error message text is saved on my desktop at work and I forgot to bring it home with me. I was just hoping to get a head start on this situation.
The errors are showing up for multiple reasons. So, I was wondering, at this point, if it would be better to just start over from scratch (with style manager settings) or if there is an easy way to make a custom style settings file work without error.
I meant to say "Design Data" , and now see the code error below...
... I found these lines in the XML file but do not know what value to change the errors to.
Invalid XML value for 'SubstituteDisplayUnit'. Expected 'bool' received '186'
in file:///C:/Users/Public/Documents/Autodesk/Inventor%202013/Design%20Data/PartsList.xml.
Invalid XML value for 'SubstituteLeadingZeros'. Expected 'bool' received '113'
Invalid XML value for 'SubstituteTrailingZeros'. Expected 'bool' received '117'
Invalid XML value for 'SubstituteFractionalFormat'. Expected 'bool' received '240'
Invalid XML value for 'SubstituteDisplayUnit'. Expected 'bool' received '200'
Invalid XML value for 'SubstituteLeadingZeros'. Expected 'bool' received '187'
Invalid XML value for 'SubstituteTrailingZeros'. Expected 'bool' received '7'
Invalid XML value for 'SubstituteFractionalFormat'. Expected 'bool' received '24'
Hi, I just got this error also when trying to edit a sketch in an .idw.
I opened the Parts Lists Styles editor then done and went to edit the sketch and it worked.
Well, to be more specific ... here is the latest from INVENTOR when I try saving "local styles" to main library.
"Style library (C:\Users\Public\Documents\Autodesk\Inventor 2013\Design Data\) cannot be saved because it is damaged."
Please help, thanks.
