Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Derive iMate from multi body part
6 REPLIES 6
saseendrankombath
662 Views, 6 Replies
How to derive only referenced imates to the solid from multi body part.
6 REPLIES 6
Please find attached result after deriving all imates thru api I want to import only the required ones
When deriving a component, you can iterate through each derived entity and specify if it has to be included or not. You could check for iMateDefinition and use "iMateDefinition.ReferencedEntity" property to determine if you want to derive this iMate or not.
Here is a sample code that checks parameters:
Public Sub CreateDerivedPart()
    Dim doc As PartDocument
    Set doc = ThisApplication.ActiveDocument
    Dim derivedDoc As PartDocument
    Set derivedDoc = ThisApplication.Documents.Add(kPartDocumentObject, _
        ThisApplication.FileManager.GetTemplateFile(kPartDocumentObject), _
        True)
    Dim derivedPartComps As DerivedPartComponents
    Set derivedPartComps = derivedDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents
    Dim derivedPartDef As DerivedPartUniformScaleDef
    Set derivedPartDef = derivedPartComps.CreateUniformScaleDef(doc.FullDocumentName)
    derivedPartDef.ScaleFactor = 0.75
    'derivedPartDef.ExcludeAll
    'derivedPartDef.IncludeAlliMateDefinitions
    'derivedPartDef.IncludeAllSurfaces
    Dim derivedEntity As DerivedPartEntity
    For Each derivedEntity In derivedPartDef.parameters
        If (TypeOf derivedEntity.ReferencedEntity Is parameter) Then
            Dim parameter As parameter
            Set parameter = derivedEntity.ReferencedEntity
            Debug.Print "Derived Parameter: " & parameter.name
            'Choose to include entity or not
            'derivedEntity.IncludeEntity = False
        End If
    Next
    derivedPartDef.DeriveStyle = kDeriveAsSingleBodyNoSeams
    Dim derivedComp As DerivedPartComponent
    Set derivedComp = derivedPartComps.Add(derivedPartDef)
End Sub
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Thanks for your valued replay. But I need some more help from you. Can you please explain the correct usage of imateDefinition.ReferencedEntity to select the required imates. I was trying but unsuccessful on this. My actual requirement is ..... I have a multi body part with imates having same name but on different solid bodies of the multi body part. Then I am using make components to derive the solid bodies in to parts and to an assembly. After this I want to derive imates referenced to each solid body to the corresponding derived part. Please find the code which I was trying and the same derives all the imates. I need your help to solve this issue. Awaiting for your valued help.
Public Sub editDerived()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim derivedPartComp As DerivedPartComponent
Set derivedPartComp = oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1)
Dim oderivdef As DerivedPartUniformScaleDef
Set oderivdef = derivedPartComp.Definition
For Each derivedEntity In oderivdef.iMateDefinitions
If (TypeOf derivedEntity.ReferencedEntity Is iMateDefinition) Then
Dim oiMate As iMateDefinition
Set oiMate = derivedEntity.ReferencedEntity
derivedEntity.IncludeEntity = True
End If
Next
oderivdef.DeriveStyle = kDeriveAsMultipleBodies
derivedPartComp.Definition = oderivdef
End Sub
Here is the modified code, I am checking the included bodies status and set that to the derived iMateDefinition. In my test data set, the iMates are attached to faces, but I think the code will work for any brep entity:
    Set derivedPartComp = oDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents.item(1)
        Dim iMateDef As iMateDefinition
        Set iMateDef = derivedEntity.ReferencedEntity
        Dim bodyName As String
        bodyName = iMateDef.entity.Parent.name
        Dim derivedSolidEntity As DerivedPartEntity
        For Each derivedSolidEntity In oderivdef.Solids
            Dim surfbody As SurfaceBody
            Set surfbody = derivedSolidEntity.ReferencedEntity
            If surfbody.name = bodyName Then
                derivedEntity.IncludeEntity = derivedSolidEntity.IncludeEntity
            End If
        Next
    Next
End Sub
Philippe.
Philippe Leefsma
Thanks a lot
This works well as I expected. Once again Thanks for helping.
With Regards,
Saseendran Kombath
Interplast Co. Ltd.,
Sharjah, U.A.E
No problem.
Philippe.
Philippe Leefsma
