Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Deletingcustom properties with ilogic
7 REPLIES 7
Message 1 of 8
1538 Views, 7 Replies
Hello All,
I want to clean up some custom properties with a externe ilogic rule. I want run it in a iam and than delete some custom properties in the parts. So if they are there in the part, than delete them. But I don't get the code right working. I want delete the custom property "R8_item_nummer"
Here I have some code:
' set a reference to the assembly component definintion.
' This assumes an assembly document is open.
Dim oCompDef As AssemblyComponentDefinition
oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
oCompDef.RepresentationsManager.LevelOfDetailRepresentations("Master").Activate
InventorVb.DocumentUpdate(True)
Try
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oCompDef.Occurrences
    ' Set Reference to Part Document
    Dim invPart As Document
    invPart = oOccurrence.Definition.Document
    ' Set Reference to Part's iProperies
    Dim oPropertySets As PropertySets
       oPropertySets = invPart.PropertySets
    Dim oValue1 As String
    Dim oValue2 As String
    Try
    oValue1 = iProperties.Value(oOccurrence.Name, "Custom", "R8_omschrijving")
    iProperties.Value(oOccurrence.Name, "Project", "Description")=oValue1
    Catch
    End Try
    Try
    oValue2 = iProperties.Value(oOccurrence.Name, "Custom", "R8_item_nummer")
    iProperties.Value(oOccurrence.Name, "Custom", "R8_GRND_ITEM_NUMMER")=oValue2
    If oOccurrence.Name = "R8_item_nummer" Then
    'delete the custom iProperty
    Else
    Catch
    End Try
Next
Catch
End Try
Jorn
7 REPLIES 7
Message 2 of 8
Jon.Dean
Did this code work in an earlier release?
Jon.
Jon Dean
Message 3 of 8
in reply to: Jon.Dean
The code works, but:
Here I mis something. text here must be that the iProperty must be removed in the part.
Else
Message 4 of 8
Jon.Dean
Here is one idea:
'define custom property collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
'look at each property in the collection
For Each oCustProp in oCustomPropertySet
'check for a property name that you don't want to delete
If Not oCustProp.name = "HelloWorld" Then
oCustProp.Delete
Else
Next
Check also the following thread.
Jon.
Jon Dean
Message 5 of 8
Thank you for your answer.
This is a code when you want to run it in a part.
But I want to run it in a assembly, and then it delete the properties in the parts.
Message 6 of 8
Jon.Dean
If you do it from the Assembly, then you would need to know the name of every part in the assembly or generate code to make a set.
Then you could work through each part in turn, deleting the property.
It is starting to sound more like VB task.
Jon.
Jon Dean
Message 7 of 8
ewiggers
Hello Jorn,
Put the following code into an external rule and it should do the job for you:
Option Explicit
' Rule to delete custom properties from all parts present in the Assembly
Dim oAssyDoc As Document = TryCast(ThisApplication.ActiveDocument, AssemblyDocument)
Dim oCompDef As ComponentDefinition
Dim oOccurDoc As Document
Try
	If (oAssyDoc IsNot Nothing) Then
		' Set the component definition
		oCompDef = oAssyDoc.ComponentDefinition
		' Loop thru all the occurences
		For Each oOccurrence As ComponentOccurrence In oCompDef.Occurrences
			oOccurDoc = oOccurrence.Definition.Document
			If (oOccurDoc IsNot Nothing) Then
				For Each oProp As Object In _
oOccurDoc.PropertySets.Item("Inventor User Defined Properties") ' Check for the right name to delete If (oProp.Name = "Your Custom Property Name") Then oProp.Delete End If Next oProp End If Next oOccurrence Else MsgBox("This rule only works from an Assembly Document", _
vbOKOnly, "DeleteCustomProperties") End If Catch ex As Exception Dim sMsg As String = "Error info: " Dim Style As Integer = vbOKOnly Dim sTitle As String = "Error: DeleteCustomProperties" MsgBox(sMsg & vbNewLine & ex.Message, Style, sTitle) End Try
If you have more than one Property to delete use the following code:
Option Explicit
Try
oOccurDoc.PropertySets.Item("Inventor User Defined Properties") ' Check for the right name to delete Select Case oProp.Name Case "Your first Custom Property Name", _
"Your second Custom Property Name" oProp.Delete End Select Next oProp End If Next oOccurrence Else MsgBox("This rule only works from an Assembly Document", _
Eelco
Message 8 of 8
dusan.naus.trz
I need to delete all iProperties starting with the name "Color". I don't know what I'm doing wrong.
rule Delete_Select_iProperty
Dim suffix As String = oCustProp
i= "Color" 'where i is the first letter to start with'
For Each oCustProp In oCustomPropertySet
If oCustProp.name = i & suffix Then
i = Chr(Asc(i)+1)
oCustProp.Delete
Else
Next
