I have seen post on deleting all contraints in an Assembly, but I haven't been able to find any information in the API or anywhere on the internet on deleting a specific constraint of an occurrence or all the constraints of a specific occurrence within an assembly.
You'll have to go through the constraints in the assembly and then see which ones involve a specific occurrence and delete those.
You can simply select a constraint in the user interface and then investigate its properties in VBA:
http://adndevblog.typepad.com/manufacturing/2013/10/discover-object-model.html
Cheers,
Thanks for the replay. This is what I ended up doing in the meantime. Wasn't sure if there was another easier option out there.
