I've tried to search for this for awhile and i came up empty. I'm simply trying to delete the revision table if it exists on a drawing. I did find where you can't do anything with Rev Tags with the API, but what about the Actual Revision Table?
Trying to get this to work;
If iProperties.Value("Project", "Revision Number")>0 Dim oRevTable as RevisionTable oRevTable = ActiveSheet.Sheet.RevisionTable.Item(1) oRevTable = nullRevisionTable
Solved by Vladimir.Ananyev. Go to Solution.
RevisionTable.Delete method deletes this RevisionTable object.
