Delete Revision Table
2 REPLIES 2
Ktomberlin
607 Views, 2 Replies
I've tried to search for this for awhile and i came up empty.  I'm simply trying to delete the revision table if it exists on a drawing.  I did find where you can't do anything with Rev Tags with the API, but what about the Actual Revision Table?
Trying to get this to work;
If iProperties.Value("Project", "Revision Number")>0
Dim oRevTable as RevisionTable
oRevTable = ActiveSheet.Sheet.RevisionTable.Item(1)
oRevTable = nullRevisionTable
2 REPLIES 2
RevisionTable.Delete method deletes this RevisionTable object.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Got it working thanks
If iProperties.Value("Project", "Revision Number") > 0 Then
ActiveSheet.Sheet.RevisionTables.Item(1).delete
End If
