Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Delete a VBA macro from an add-in
10 REPLIES 10
Message 1 of 11
342 Views, 10 Replies
I haven't even started looking at this yet but thought someone might know
off the top of their head.
Any way to delete the VBA code from a part via an add-in. I was thinking of
ways to overcome the problem of having too much code in the part files in a
large assembly. This way you could run the code on creation but when you
save the VB add-in deletes the code form the part.
Thinking out loud mainly... any comments?
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
10 REPLIES 10
Message 2 of 11
Sean
I think it could be done using VBE. Wonder if it wouldn't be easier or better to have a
addin that did what you wanted to the files on creation?
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Sean Dotson" wrote in message
news:6F8E2F3CF30786CADE740C1147A72716@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
Message 3 of 11
That could be the case but I'd require several add-ins. The code is some
simple stuff that runs when you create the part. However it's different for
each part. So I'd like to run the part code then get rid of it.
So are you saying use SendKeys to the VBE to get rid of the code?
Sean Dotson, PE
"Kent Keller" wrote in message
news:4E1DDE797919503AC3F5B9E6C45951AC@in.WebX.maYIadrTaRb...
> Sean
better to have a
> Kent
> Assistant Moderator
know
thinking of
in a
you
> > Sean Dotson, PE
Message 4 of 11
No, not SendKeys. I think if you look in the VBA help (not Inventor) there is some info
on VBE. I seem to remember a example somewhere in there where it would add code to a
module so it stands to reason you could also remove code.
If you can't find it give me a buzz and I will take a look when I get a chance.
Kent
Assistant Moderator
"Sean Dotson" wrote in message >
> Sean Dotson, PE
Message 5 of 11
Ah gotcha. I was misunderstanding your suggestion. Thanks Kent.
Sean Dotson, PE
news:63CEF093C5FA3F56FBD510666D3CB190@in.WebX.maYIadrTaRb...
there is some info
add code to a
chance.
> Kent
> Assistant Moderator
> > Sean Dotson, PE
Message 6 of 11
avbuiten
You want probably something like the code below.
Use the Local WIndows to explore the posibilities.
I don't think you can delete or unload entire files.
'you need a reference (VBA: Tools>Reference, VB>Project>Reference) to:
' Microsoft Visual Basic for Applications Extensibility 5.3
Sub Main()
Dim app As Application
Dim vbe As vbe
Dim nLines As Long
Set app = ThisApplication
Set vbe = app.vbe
Debug.Print vbe.VBProjects(1).Name
nLines = vbe.VBProjects(1).VBComponents(1).CodeModule.CountOfLines
Debug.Print vbe.VBProjects(1).VBComponents(1).CodeModule.DeleteLines(1, nLines)
End Sub
Message 7 of 11
Thanks Anton.  Just starting to look into how
to handle this idea...
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
Check the Inventor
href="http://www.sdotson.com/faq.html">www.sdotson.com/faq.html
files.
to:
Sub
Main()
    Dim vbe As vbe
    Dim
nLines As Long
    Set vbe = app.vbe
    nLines =
    Debug.Print
End
Sub
Message 8 of 11
avbuiten
With pleasure.
Message 9 of 11
What else can you do with this Applications
Extensibility library?  Could this library be used for comprehensive
error logging?  I've heard about error classes..... and that's about it,
I've spent a long time thinking about howpeople make them and how people
implement them.  I feel it would be good idea to have an error log
available when beta testing an add-in and it decides to throw a
wobbly,I think this library is the interface I have been looking for, my
perceptions of the library lead me to belive I could get the exact line
number, procedure etc, I think it may be possible to monitor the variables being
used in this case aswell in my add-in when it breaks.
.... I don't know, just thinking aloud, wondering,
any thoughts, suggestions, corrections greatly appreciated.
Scott
Message 10 of 11
..... don't know about anyone else, my help won't
work for this library, bit of a bummer under the circumstances, can some one
suggest where I can get them from.
Scott
Message 11 of 11
Have you tried google Scott?
http://www.google.com/search?sourceid=navclient&ie=UTF-8&oe=UTF-8&q=%22Applications+Extensibility+library%22
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
"Scott" wrote in message
news:78D55D7A1394C0875771C677467A4932@in.WebX.maYIadrTaRb...
> ..... don't know about anyone else, my help won't work for this
library, bit of a bummer under the circumstances, can some one suggest
> Thanks
> Scott
